Old 07-07-2013   #1
cliford_thefast_redcar
Drives: 95 gsx
Axle bracket bolts broke??
So I have been told that they make two different front axles for my car could that be the reason why the bolts broke again in my block if so how do I figure out if I got the right axles
cliford_thefast_redcar is offline   Reply With Quote
Old 07-07-2013   #2
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Axle bracket bolts broke??
They make two different brackets. The axles are all the same unless abs to non but that diesnt really matter either. Axles shouldn't cause the bolts to break.
Mine was flopping and came right out no broke bolts or anything. Your either not using the right bolts with lock washers or you are not spacing it correctly.
Old 07-08-2013   #3
Drives: 95 gsx
The last time I replace them I used oem bolts and the same way Joel cut his ax braket off for the spacer so I have all oem stuff coming the bolts washers and the spacer
