Old 05-12-2014   #1
M1L3S
M1L3S's Avatar
Drives: 99Gst
dsm link v3 tuning help :/
Hey was wondering if any local guys would be willing to give me a hand with street tuning.
Im kinda lost with it. My set up is pretty basic. Just looking for some help and pointers.
Anytime this week would be awsome.
I could give you some free parts for your trouble or work something out with you.
M1L3S is offline   Reply With Quote
Old 05-12-2014   #2
Fran05
Drives: DSM
Re: dsm link v3 tuning help :/
http://www.ecmtuning.com/wiki/ecmlink101
Old 05-12-2014   #3
M1L3S
M1L3S's Avatar
Drives: 99Gst
Originally Posted by Fran05 View Post
i have been doing a lot of reading, even bought the book listed in the ecmlink forum. this stuff is basically a foreign language!
im not asking for someone to spoon feed me. I just have absolutely no idea what im looking at or doing. I dialed in the .63 volts. checked timing.
I see why tuners get payed so well.
I just need someone to show me the ropes so Im not so scared to actually adjust and change things :/
Old 05-12-2014   #4
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Post your mods/setup, your logging a wideband right?
Old 05-12-2014   #5
I'm kinda the same way, I understand it, but it's definitely not my specialty. I just bring my car to Shane at DB and have him tune it. I don't have to worry about blowing anything up and I'm getting max power out of my setup. I sometimes make little changes from there.
Old 05-12-2014   #6
dsmghost
dsmghost's Avatar
I'm comfortable with speed density but have no experience with tuning maf. I would need to do a little research prior, but it wouldn't be a problem. As long as the car runs solid and is set up ok with a wideband etc. I have a nice loop by my house to do consistent identical pulls for wot tuning but this week there is road work.
Old 05-12-2014   #7
I'm off friday, i could help then if needed.
Make sure the car is boost leak tested, you have tools and fluids on hand.
Old 05-12-2014   #8
M1L3S
M1L3S's Avatar
Drives: 99Gst
Mod list.
272 cams
adjustable cam gear
2.3
1600cc injectors(running gas and 450cc now just while I get the hang of things)
Gm maft.
V3 link
3 exhaust
all the supporting mods.
Hx35 7blade (sitting on the shelf for next summer )
Basically ive just driven it around the block and adjusted maft comp sliders based on the recommendation of link.
I set the base settings to where they should be. But in all honesty im sure I may have missed a few values that I need to log.
I wish I could afford db.
Im not looking to put down max hp/torque
just want it tuned reasonable and driveable.
Next summer I plan to go balls to the walls. But this summer I just want to get the basics down. Learn to tune properly.
Thank you guys for replying btw. The ecmlink forum is pretty rough. Im not a master tuner so it feels like they look at you as if you were a 420a guy asking why you cant swap in a 4g63t :/
Old 05-12-2014   #9
mondale
Drives: 1g dsm
I think that you should give the link forums another go. I have not got that demeaning vibe from that forum when I asked for help. You WILL get that attitude if you post up questions without a log, or do not have accurate/incomplete information that you are feeding them to look better. I know that sounds silly but it happens. There are a lot of really smart guys on that forum that are willing and eager to help you get a very good tune for free. You could even pay a few members there a minimal fee to remote tune your setup so you don't have to worry about anything.
8.59 @ 158
mondale is offline   Reply With Quote
Old 05-12-2014   #10
M1L3S
M1L3S's Avatar
Drives: 99Gst
http://www.ecmtuning.com/forums/show...768#post648768
the thread I just posted up
and on tuners
http://www.dsmtuners.com/forums/tuni...#post153427974
Old 05-12-2014   #11
dsmghost
dsmghost's Avatar
Originally Posted by M1L3S View Post
Mod list.
272 cams
adjustable cam gear
2.3
Gm maft.
V3 link
3 exhaust
Your logging a wideband right? I dont have my laptop right now so I cant look at your logs you posted on the link forum yet.
Whats your current turbo?
Old 05-12-2014   #12
M1L3S
M1L3S's Avatar
Drives: 99Gst
And whats your current turbo?
yes, I have a wideband.
one thing I noticed is that my wideband reads anywhere from 16-18 at idle.
isn't that crazy lean?
but then when I look at my logs it says different?
I have the white wire on my wideband ran to pin 75 on my ecu as well
Old 05-12-2014   #13
dsmghost
dsmghost's Avatar
Before any tuning at all you need to have your WB gauge and your WB logged to be the same.
Old 05-12-2014   #14
Just post a thread there saying you just started the car, but they do expect you to be able to follow simple instructions and do base checks.
The other important thing there is to post up logs of what you are dealing with.
Old 05-12-2014   #15
dsmreck
dsmreck's Avatar
Drives: 98 gsx
I would just take $100 and get yourself on speed density. Tuning is so much easier on sd. The car will pretty much tune itself after you dial in the idle for everything but wot. As soon as I get off work I will post a link that will explain everything you will need to know in full easy to understand detail.
Old 05-13-2014   #16
M1L3S
M1L3S's Avatar
Drives: 99Gst
would you still be able to post the link?
Old 05-12-2014   #17
dogwhistle
dogwhistle's Avatar
I am also able to help tune in person and show you anything MAF related. Most these guys are much better with SD than I and if you go that route I'm no good but I was able to learn lots from tuning with Shane twice and tuning several other cars to run better and cleaner after builds. Just shoot me a PM if you need.
-Adam
aneujahr@maperformance.com
Old 05-12-2014   #18
Go on link and edit your sig to show your significant mods. (no suspension, but cams, intake, exh, turbo, fuel pump, injectors, etc)
People will need to know mods to know what they are tuning there.
Old 05-12-2014   #19
SlowWhite
Been there, done that.
SlowWhite's Avatar
Been looking at 2 cars both running v3 on sd. Hope to pick up one of the two week of memorial day.
And after a quick read up. I'm sure I'm going to have a ton of questions also as it doesn't look any thing like v2 that in used to run.
Anyone on here able to do the online tuning if we give logs? One car is only tuned for e85 and if I go with that car I'd need to basically do a full 93oct tune. As driving from west palm beach to south carolina is going to be difficult trying to find stations with E85.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 05-12-2014   #20
dsmghost
dsmghost's Avatar
Yeah quite a few of us can do that. It's actually pretty simple stuff once you start doing it yourself.
