Old 11-05-2004   #1
enasnitsi
Guest
Tournaments Won: 6
Posts: n/a
Optional Biss adjustment
I was just wondering if I can just adjust the BISS screw instead of doing what it says in the VFAQ. I don't have a scan tool and I don't want to bring it in and have some shop screw up my car. Is there any other possible methods because my car has been dying after I run it for a short while. Any help would be great.
Thanks
Old 11-05-2004   #2
You can try it. Mark where it is first and coutn the turns out fdrom fully closed, then try adjusting it. If it doesn't help, put it back where it was.
It's much easier with the scan tool engaged.
Old 11-06-2004   #3
enasnitsi
Guest
Tournaments Won: 6
Posts: n/a
I guess I will give that a try. I didn't know if it would wreck anything if I did that, if it doesn't work I will try replacing the o-ring that is underneath it.
Thanks
Old 11-06-2004   #4
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
cant you just ground it? Thats what my buddies with 2gs do.. If you ground it out, the ecu doesnt tamper with the idle when your trying to adjust it. Just my 02, if you have a 1g, grounding is a lil more complicated =/
- Josh L.P.
Old 11-06-2004   #5
Give it a counter-clockwise turn or so and see how that helps and go from there (more or less of a turn). Worse case senario, you just screw up your idle.
