Old 03-02-2005   #1
DeAdGnRaTiOn
Send a message via AIM to DeAdGnRaTiOn Send a message via MSN to DeAdGnRaTiOn
Installing the MAF-T 2.01
It looks like it is just plug and play but there are 2 loose wires. A white wire and a blue wire with the tips pre-spliced. What do I do with these 2?
DeAdGnRaTiOn is offline   Reply With Quote
Old 03-02-2005   #2
Re: Installing the MAF-T 2.01
wite wire goes to rpm signal (wite wire coming off CAS is a good lead), the blue wire is the aux lead, if you want to make adjustments for when you're running h2o or n2o injection.
Old 03-02-2005   #3
LightningGSX
Hellbound
IIRC the white is the RPM signal, which connects to the CAS and the blue is an AUX of some kind
EDIT: Scheides beat me to it.
-Nulli Secundus-
Old 03-02-2005   #4
DeAdGnRaTiOn
lol, thanks alot guys!
Old 03-02-2005   #5
Thumbs up Re: Installing the MAF-T 2.01
ha!
Old 03-02-2005   #6
DeAdGnRaTiOn
Will there be a blue wire off the CAS that I can splice in to..or what should I be looking for?
Old 03-02-2005   #7
White wire off the CAS...solder that to the white wire on the maf-t. leave the blue wire alone, tape it off.
