04-19-2005
#1
Mr. Me Too
Drives: Suzuki GSXR
Shift from AWD to FWD.
Japanese Domestic Market (JDM) Galants were available with a switchable tranny/transfer case combo, allowing you to switch to FWD simply by removing a bolt and bracket from the tranny and transfer case. Removing the bolt from the tranny allows the plunger in the case to extend, locking the center diff down. Removing the bolt from the transfer case allows the plunger to retract, unlocking the shaft, allowing the transfer case to freewheel. I need to find one of them!!
Take her to the limit!
04-19-2005
#2
Re: Shift from AWD to FWD.
This is new info?
04-19-2005
#3
You can find one on eBay every once in a while, but I don't know of anybody using it.
When she get's bitchy, SPANK THAT ASS! (#Y#)
04-19-2005
#4
Mr. Me Too
Drives: Suzuki GSXR
Not really new info.
just FYI for who ever.
04-19-2005
#5
Never heard of that, wow that would be nice. Have to keep my eye out.
04-19-2005
#6
OLD! If your going for tons of power, I have heard these are weaker.
04-19-2005
#7
Mr. Me Too
Drives: Suzuki GSXR
I'm not sure if its weaker, I would have to look inside of one. but I would be putting ont in a stock talon AWD for hopes of better MPG.
04-19-2005
#8
new to me, now wouldnt it be nice if you could do that inside the car or while moving, you could get the AWD launch and then switch it off once your moving so you dont get all the parasitic loses in hp.
I dont know, if i stated thaqt as accuratly as possible, but im sure some one understands what im saying
04-19-2005
#9
Big Turbo Monster
Drives: GTS and E55
John has one that he will be putting into his talon. After he gets mike to weld a vc, all he has to do is drop a bolt to dyno from awd to fwd.
7/25/09
04-19-2005
#10
The output shaft going to the driveshaft on the switchable JDM transfer cases have been known to snap.
04-20-2005
#11
So is it just a transfer case that is different or is the "bolt" in the transmission? What parts would you need to swap out to make it work with a 1G.
Does it match up to the splines on our trannys here? I have no idea how it works... as Ive never heard of this before.
I assume its weak basically like having a 3bolt versus a 4bolt rear end?
04-20-2005
#12
The RTFVfaq Guy
Doesn't anybody look at vfaq.com anymore?
http://www.vfaq.com/mods/Tranny-switchable.html
They are all 22 spline.
"We are the music makers, and we are the dreamers of dreams."
04-20-2005
#13
Business as usual
They are exactly the same as far as bolting them in but can be switched. I was told that mine was modified to be switchable, it was not a JDM part. I am not sure though. I got it from Joem. What is a ton of HP or enough to break the imput shaft?
97 Viper GTS
04-20-2005
#14
A 20G.
04-20-2005
#15
Business as usual
Originally Posted by ecoli
A 20G.
We will see how it lasts then  I should be in the 20g power range... I have a backup t-case just in case.
97 Viper GTS
04-20-2005
#16
That transfer case actually is the JDM one. It came as a switchable, it was not modified.
04-20-2005
#17
Business as usual
Oh, I thought he said he looked up the parts and converted it or something. I must have heard him wrong then.
97 Viper GTS
| Thread Tools |
| Display Modes |
Hybrid Mode
