Old 06-06-2005   #1
Compression Test Results
1992 Tsi AWD 5spd 6bolt 139k mi
I finally did a compression test today on my car:
Cold, Dry test
#1:105
#2:139
#3:140
#4:148
Wet Test (capful of oil)
#1:135
#2:155
#3:170
#4:175
No wonder my car is so slow...
This means worn rings right (they all went up with wet test, not stay the same i.e. a valve issue)? Time for rebuild...
Old 06-06-2005   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: Compression Test Results
No rebuild, just more boost?
J/K
Take her to the limit!
Old 06-06-2005   #3
haha.
Old 06-06-2005   #4
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
And some NAWWZ!
Old 06-06-2005   #5
yeah thatd be tight yo. lemme bust out my pro fogger fo hizzle 500 shot.
Old 06-06-2005   #6
MustGoFaster
Sound like you have a plan to even that compression out. To zero.
Old 06-07-2005   #7
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Wasn't that motor just rebuilt when Blake owned it. (by shindley)
'04 Honda Ricer: stock
Old 06-07-2005   #8
xluciusx
Send a message via ICQ to xluciusx Send a message via AIM to xluciusx Send a message via MSN to xluciusx Send a message via Yahoo to xluciusx
ouch man
xluciusx is offline   Reply With Quote
Old 06-07-2005   #9
Blake didn't mention it to me? I probably screwed it up though.
Old 06-07-2005   #10
Wet test is kinda useless on a motor with dished pistons. The oil just sits in the dish and raises the compression.
Old 06-07-2005   #11
blageo23
AWD4G64
blageo23's Avatar
Sounds like your engine is gonna blow up! Just throw a 2.4 in there and be done!!
Old 06-07-2005   #12
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Thread cleaned up. Keep this thread on topic from here on out. If you aren't giving sleepydsm opinions on his results then shut up and start your own thread. If you want to know how to compression test your own car then start another thread addressing that issue on your own and we will be glad to help.
CRAIG
Old 06-07-2005   #13
It isn't *that* bad except for #1. The engine has to be at full operating temp to get accurate results. Drive the car around for 20 mins and try it again.
Old 06-07-2005   #14
blageo23
AWD4G64
blageo23's Avatar
yah we def didnt do that. we'll try it again and post up new ones.
Old 06-07-2005   #15
Raptor
ConArtist
Raptor's Avatar
Glad someone said something about that, it should'd do anything to even out the cylinders though which is actually the bigger issue. Like Shane mentioned, the wet test is somewhat tricky with any dish to the pistons. there is typically .300 above the ring to the crown that oil can ride in without going into the center, but it is a bit tricky to get it in there accurately. I have a few tricks to do it, stop by the shop and I can tell you how if you like.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 06-07-2005   #16
john
Business as usual
john's Avatar
I will let you know what kind of difference lower compression makes. I will be testing on a car with (4-1) 140-140-130-90.
97 Viper GTS
Old 06-07-2005   #17
Sounds good. I am redoing the compression test tomorrow, at operating temp just for shits.
Old 06-08-2005   #18
blageo23
AWD4G64
blageo23's Avatar
SLEEPYDSM's new test numbers:
1-120
2-130
3-150
4-150
Rings? Headgasket? Is his next step a leakdown test?
Old 06-08-2005   #19
Run 'er til she blows! It is probably valve seals or rings though.
Old 06-09-2005   #20
Raptor
ConArtist
Raptor's Avatar
You meant valve seats right?
651-488-7774
