Old 06-23-2005   #1
xluciusx
Send a message via ICQ to xluciusx Send a message via AIM to xluciusx Send a message via MSN to xluciusx Send a message via Yahoo to xluciusx
internal damage?
With the hot weather my car has been getting really hot and I mean REALLY hot today I saw the temp gauge hit 210... and it has been acting really strangly. Then on my way home from a friends house I heard a loud clunk follow by some horrible grinding scraping noises, then the car died. I stopped immediately but I don't see anything visibly wrong, if I try to start up the car it makes the same horrible noises. How fucked am I?
xluciusx is offline   Reply With Quote
Old 06-23-2005   #2
john
Business as usual
john's Avatar
Re: internal damage?
Are there any belts off? The crank pulley could have seperated, the alt belt fallen off and the waterpump stop spinning.
97 Viper GTS
Old 06-23-2005   #3
xluciusx
oh so here is what i checked. I looked at the compressor wheel on the turbo, look and spun fine. i also checked the spark plugs to see if they got hit by something but they looked fine. all the belts were on and felt tensioned appropriately.
I think I may have thrown a rod or maybe my fly wheel exploded, I dont fucking know....
Old 06-23-2005   #4
Onefast99gsx
I don't know what it could be based on that but i wouldn't drive the car anymore until i could draw some conclusions. A $20 fix on something it may be could turn into several hundred or over a $1,000 damage.
BTW- 210 degrees isn't anything out of the ordinary. Start getting over 213-215+, then she's getting pretty hot.
Old 06-24-2005   #5
Depends if it's a 1G or 2G. 210 is normal on a 2G but hot on a 1G.
Old 06-24-2005   #6
xluciusx
its a 2g with a 6 bolt. I normally run around 190 and the needle was definitely over 210 but past that point its hard to tell cuz the next mark is 250
Old 06-24-2005   #7
Does it even turn over?
Old 06-24-2005   #8
Enes
Enes's Avatar
don't crank it with starter, do it by hand and see how it feels..
Old 06-24-2005   #9
xluciusx
Yes it does turn over. I tried it once after it initially died and letting it cool down for a bit. Still sounded like hell...
Haven't tried turning it my hand
Old 06-24-2005   #10
Enes
Enes's Avatar
oopsy... good luck...
Old 06-24-2005   #11
pull the oil pan & see what's in it. MIne made that noise one morning and it was just one of the oil squirters. I replaced that & it was fine.
Old 06-24-2005   #12
Onefast99gsx
Do a compression test(if you can). Pull the valve cover off and do a visual on the rotating parts up there. If you don't see anything, then it's time to pull the pan off. Could have been just about anything in there. Put a breaker bar/socket on the crankshaft bolt and rotate the engine over by hand(pull the spark plugs so it's easier). DO NOT start it. You already know it's sounds like shit in the condition it's in.
Old 06-24-2005   #13
Yeah, definatly pull the oil pan. If something went in the lower end chances are when you pull the pan your gonna find out what it is.
Old 06-24-2005   #14
xluciusx
thnx for all the advice so far I'll check it all out this saturday.
Old 06-24-2005   #15
Onefast99gsx
When and if you're in their checking around, check the bottoms of the pistons too to make sure a piston skirt didn't bust off or something.
Old 06-25-2005   #16
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
im guessing it went a little past 210 and something got a little too hot heh. Drop the pan and examine the oil. That should tell you alot.
- Josh L.P.
Old 06-25-2005   #17
I would expect the worst though, it doesn't sound too good.
Old 06-25-2005   #18
xluciusx
I messed around with it a little tonight. Pulled the valve cover, everything looked fine there (as expected). Turned the engine over by hand, it gets real hard to turn when the timing mark is at the 12, 3, 6, and 9 o'clock positions but then moves smoothly once I get it past that point, and it didn't seem to make any noise or feel rough between. I didn't get the pan off, holy crap that is a lot of work. Am I going to have to drop my transfer case and down pipe? They both go under the pan and I don't see how you can get it off w/o getting them out of the way too.
Old 06-26-2005   #19
Yep, both have to come off.
Old 06-28-2005   #20
john
Business as usual
john's Avatar
How about you just try and drain the oil first. Maybe you spun a bearing. If so, there may be metal shavings in the oil. You could also have someone check it out with a boroscope instead of removing the pan. Ofcourse the oil would have to be gone first. It will save you an assload of time if Mike gets out of the hospital or you can find someone vs pulling the pan.
97 Viper GTS
