Old 09-03-2005   #1
94talonawd
94talonawd's Avatar
Send a message via MSN to 94talonawd
did 93 dissapear? why do i only see 92?
hey just wondering... like last year i saw a lot of 93 octane at gas stations when i had my integra.. and now when i just got my tsi, i dont see anymore 93? what the..... do we not have 93 anymore? haahaha
94talonawd is offline   Reply With Quote
Old 09-03-2005   #2
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: did 93 dissapear? why do i only see 92?
I think Holiday is one of the only stations that carry 93octane, most are 92.
Old 09-03-2005   #3
TheBlizzard
Drives: Too Many
BP/Amoco 92 is the best pump gas you can get around here in my opinion.
Old 09-03-2005   #4
94talonawd
94talonawd's Avatar
what about the non-oxygenated gas that comes from crappy looking gas stations? those are 92. u think these are better or the oxygenated ones from bp/amoco?
Old 09-03-2005   #5
TheBlizzard
Drives: Too Many
non oxygenated gas is only needed when the vehicle is going to not be used in a regular fashion. It doesn't gel up as much after it sits for awhile, you can use stabil to keep it from geling up as well. If you are going to use the gas right away it doesn't matter if its non oxygenated or not. Just use the BP/Amoco or Holiday 93, don't use SA gas though, or Citgo, ect. Unless you want a knock monster.
Old 09-04-2005   #6
Where the hell did you get that from? Non-oxygenated means non-ethanol. That means you get a little more power out of it because gas has more energy in it than ethanol.
Old 09-03-2005   #7
BP/Amoco 92 is by far the best pump gas you can get.
Old 09-03-2005   #8
Actually the best pump gas you can get is 100 octane unleaded. 92 is for sissies.
Old 09-03-2005   #9
In that case, the 110 leaded would be the best since it too comes from a pump
Old 09-03-2005   #10
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
BP in AV has 93 octane
- Josh L.P.
Old 09-03-2005   #11
One BP here in Duluth has 93 too.
Old 09-04-2005   #12
I think a lot of the non-oxy gas available may be of lower quality though, I did some testing with it back when I had my Talon and I got more knock and lower MPG with it, plus the car just didn't feel as strong.
Old 09-04-2005   #13
TheBlizzard
Drives: Too Many
I guess I should have worded it better. You should only have to worry about using non oxygenated fuel for older vehicles. Tests have shown that the contents of the oxy fuels can damage older fuels systems. So basically if you are storing your vehicle a lot and not driving it regularly, or if its really old a non oxy fuel would be a better choice. I am not sure if this pertains to DSMs, I would guess not because I have never heard of shit wearing out because of oxy fuels.
Old 09-04-2005   #14
DSM's were designed for up to 10% ethanol content, the non-oxy fuel is primarily intended for collector vehicles, boats, small engines, and other off-highway vehicles.
Old 09-04-2005   #15
You use more ethanol than normal gas, so you get worse gas mileage with ethanol. But since you use more of it, it works out to about a 1% higher power potential from the same amount of gas, even with its low BTUs. So, it's about the same. Methanol on the other hand has even less heat energy that ethanol, but you need to run so much more of it reach stoich that it ends up making 15-20% more power at the same boost level.
