Old 12-06-2005   #1
sway
Send a message via AIM to sway
misfiring.
hey guys. 95 talon tsi awd misfires badly at boost. ive changed the spark plugs/wires. thinking it could be the ignition coil, what do you think?
sway is offline   Reply With Quote
Old 12-06-2005   #2
Re: misfiring.
may also want to try swapping out the ignitor/power transistor.
could be a tuning issue, do you have any datalogging equipment?
Old 12-06-2005   #3
sway
Re: misfiring.
no i dont. car's completly stock cept for suspension, forgot to mention that.
Old 12-06-2005   #4
blageo23
AWD4G64
blageo23's Avatar
Re: misfiring.
Id test the coil and power transistor. Did u gap the plugs and put the wires in the right order.
Old 12-06-2005   #5
sway
Re: misfiring.
platinum plugs. didnt need to be gapped. and yes the wires are in the right order.
Old 12-07-2005   #6
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: misfiring.
I had ngk platinum plugs in my 97 gsx, stock, and it didn't run too well. I bought ngk bpr7es' a couple weeks ago and accel wires and it runs and idles like money now, misfiring issues gone. Except I still have some sort of lag on spool up.
Old 12-07-2005   #7
blageo23
AWD4G64
blageo23's Avatar
Re: misfiring.
Its called TURBO LAG.
Old 12-07-2005   #8
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: misfiring.
Didn't need to be gapped? Did you check them atleast to make sure? I would never trust that especially with a boosted car. Check that first thing before you go buying anything else.
I would get some NGK's anyway though, I have heard the platinums suck in DSM's too. If you are not running over 16-17psi get the BPR6ES though, the BPR7ES are more prone to fouling and are not generally needed unless you are running higher boost.
Old 12-07-2005   #9
Re: misfiring.
Somewhere along the line I've read that platinum plugs are a big NO for DSMs. As to why, I have no idea. I wish I knew, anyone care to enlighten?
Old 12-07-2005   #10
LightningGSX
Hellbound
Re: misfiring.
Anything other than the oem NGKs are a big no.
-Nulli Secundus-
Old 12-07-2005   #11
TheBlizzard
Drives: Too Many
Re: misfiring.
Oh yeah and Sway, pleast list any relative mods you have on your just if any. It will help you get answers. This problem will most likely be something really simple though.
Old 12-07-2005   #12
blageo23
AWD4G64
blageo23's Avatar
Re: misfiring.
The girl bought the cheapest wires i have ever seen. A simple wire change and all was well.
Old 12-07-2005   #13
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: misfiring.
So the problem is fixed or are you talking about someone else?
As far as not gapping/checking plugs, that is just retarded. Who knows how many times they have been dropped before they got to your hands. Also NGK BPR6ES (stock plugs) and BPR7ES (little colder than stock plugs) are the most common plugs used in DSM's. They are pre-gapped from NGK to .032 when you need them gapped to .028-.029 in your DSM.
Originally Posted by shoutbox
Old 12-07-2005   #14
sway
Re: misfiring.
problem fixed. cheap wires was causing the problem.
Old 12-07-2005   #15
blageo23
AWD4G64
blageo23's Avatar
Re: misfiring.
So what did we learn sara?
Old 12-07-2005   #16
sway
Re: misfiring.
not to buy the cheapest stuff... what can i say, im poor. =P
Old 12-07-2005   #17
blageo23
AWD4G64
blageo23's Avatar
Re: misfiring.
ATTA Girl! HAHAHA. We all gotta learn sometimes.
Old 12-07-2005   #18
Re: misfiring.
I'd ditch the platinum plugs as well.
Old 12-07-2005   #19
TheBlizzard
Drives: Too Many
Re: misfiring.
God dammit do I have to start closing tech threads when the problem is solved too? Shut up already unless you have something meaningful to add!
Old 12-09-2005   #20
sway
Re: misfiring.
Sorry i lied, problem wasnt solved. Im pretty sure its the plugs, so I'm going to go buy normal ones today and put em in. So i learned another lesson - no platinum plugs. Thanks guys!
