Old 02-05-2006   #1
blageo23
AWD4G64
blageo23's Avatar
What Gauge Should I Get?
Flame if you will... Right now I have the gauge cluster gauge holder with 2 gauges. I want to go with a triple Apillar. Right now I have boost and EGT. I need a third one. Im thinking either Oil pressure(and go with a N/A guage cluster), Oil temp or Wideband O2. Any body have any POSITIVE Input?
Thanks,
Mike
Old 02-05-2006   #2
Re: What Gauge Should I Get?
Wideband o2 would be useful.
Old 02-05-2006   #3
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Agreed on wideband O2. I also like water temp since I always had to keep on eye on that in my talon.
Old 02-08-2006   #4
Jepherz
Send a message via AIM to Jepherz
I would go with a wideband if you can afford it, since its necessary for tuning anyways. If not, go with oil pressure.
1991 GVR4 1881/2000
1993 Eclipse
Jepherz is offline   Reply With Quote
Old 02-08-2006   #5
Triple gauge:
1)Boost
2)Wideband 02
3)Oil pressure
EGT's are useless compared to the above.
Old 02-11-2006   #6
I agree, go wideband. PLX-M250 w/ gauge or something similar. Best way to see wtf is going on.
Old 02-11-2006   #7
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
oil psi water and boost..what I run.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 02-11-2006   #8
Boost
EGT
W-B O2
I dis-agree with the "EGT is useless" attitude. If you understand what it's telling you, there is some good info in those readings.
Old 02-11-2006   #9
An EGT gauge is mostly only useful, if you are running a stock ECU and you don't have a way to datalog timing. Then you can somewhat use it to know when you are knocking bad and the stock ECU is severly retarding the timing. Otherwise, it doesn't tell you if you rich, lean, or even close to tuned correctly. They are useful, if you run one on each cylinder and want to do individual cylinder tuning for maximum overall power and reliability.
Old 02-13-2006   #10
Agreed.
EGT gauges are awesome if you have controlled conditions. If I had one per cylinder, and I was tuning on an engine dyno, then I'd use them.
For a street car, they are an annoyance that causes panic where there is no need for one. Unless like above, you have a stock ecu and can't datalog timing, but as far as a tuning "need" its more of an assistance who's imput isn't really needed, but you get anyway. It will tell you where your timing is shifted to, not how good of a tune you motor has.
Old 02-11-2006   #11
blageo23
AWD4G64
blageo23's Avatar
Well I already have the Boost and EGT so Im not going to get rid of them. Who makes a Wideband? I know AEM does, Anyone else?
Old 02-12-2006   #12
http://www.plxdevices.com
Old 02-11-2006   #13
blageo23
AWD4G64
blageo23's Avatar
also whats the difference between the AEM Uego and the AEM 6-in-1? Also can you use the O2 sensor in where the rear O2 goes or should it be in the O2 housing?
Old 02-11-2006   #14
Get that Autometer Clock that has been at Elite for ages
Old 02-12-2006   #15
Swifty1638
Swifty1638's Avatar
fuck that kevin! that shit's mines!!!
-A. Swift
buy the 200 electronic boost gauge at elite..tee hee
Black 1GB Mafia #1
I wanna go fast.
Old 02-12-2006   #16
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Put an altimeter for your third one.
Take her to the limit!
