Old 07-29-2006   #1
Found MY Problem
Just got the tranny out of the car. Popped the top off it real quick to have a quick look see. Here's what we found. Which fork is this?
Old 07-29-2006   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Found MY Problem
looks like the 5th gear fork. you should be able to knock the pin out of the fork and just pull it off with the gear. looks like you might have lucked out and not have to open it up. it looks like you broke part of the selector ring too.
11.35 @ 120mph
Old 07-29-2006   #3
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
I hate to say it man, but that actually looks good! Good, as in in-expensive and easy enough to fix.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 07-29-2006   #4
5th gear? Crap, I ordered a new 1-2 and 3-4 fork. Looks like I need a 5th as well then?
Old 07-29-2006   #5
joem
Drives: 1991 Talon awd auto
I have one or ten in good shape.
Joe
Old 07-29-2006   #6
The little tabs popped out too. That is what is on top of the fork. There are 3 of them held in by a clip.
Old 07-30-2006   #7
Where do those tabs belong?
Old 07-30-2006   #8
They go in from the top on the slider. The other 2 may be in there, look for them.
Old 07-31-2006   #9
OK, well I got the new 1-2 and 3-4 forks today. I ordered a new 5th gear fork. There were 2 different ones the dealer had. I just picked one, hopefully it's right.
Jet I figured out where that tab goes that you were talking about. But this little ring thing is broken. Is that called the selector ring? I guess I'll have to put one of those on order too.
Old 07-31-2006   #10
Also, VFAQ mentions this spring. My tranny does not have this spring. The whole little dealy that is surrounded by the turqoise circle, i do not have. What's up with that? Anyone know what it's called so I can order it?
Old 07-31-2006   #11
Also, I plan on double pinning these new forks. Where do you ideally want the second pin to go? Above or below the oem pin? Parrallel or Perpindicual with it? I'm assuming you use the same size pin as the OEM one in the second hole as well.
Old 07-31-2006   #12
I would go perpendicular and above or below a good amount. I don't know if I would mess with it though. The holes are actually what make the fork weak. Adding more will probably just make it worse. I would put a smaller pin in if you do it.
That broken piece is the slider or selector ring.
Old 07-31-2006   #13
Thanks for the info. I thought it was the location of the OEM hole that was the problem, so putting a second pin, where it's a little more beefy, made it more durable.
Old 08-01-2006   #14
The spring you're missing is a wave spring. You only need one pin, and someone that knows how to drive.
Old 08-01-2006   #15
Wave spring, gotcha. And I'm a horrible driver, so 2 pins for me!
Old 08-01-2006   #16
Enes
Enes's Avatar
there is a few degrees difference on the angle of the shift forks for the 2g dsms.. we found that out the hard way when we did my trany first few times.
it will look very close but it will be only off a few degrees.
Old 08-01-2006   #17
Both the forks he had on his computer were for 1g's. One was for pre-May 1991, and the others were Post-May 1991, or something like that. I guess I'll find out! Thanks for the help so far!
Old 08-04-2006   #18
More pics to show the carnage.
My trannies outcome...
-broken 5/R fork
-broken 3/4 fork
-broken 5th gear slider AND gear
Old 08-05-2006   #19
Dang thats some damage! Get it back together yet?
