Old 03-21-2007   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Seized Ground Control Screw
One of my Ground Control coilover screw seized on my 2g.. WTF is up with these things? It's like the shittiest design, I've only had them for 2 years and they're falling apart. Anyway, anyone ever deal with a seized screw in these? I drenched the screw and surrounding area with liquid wrench like 3 times.. I put so much that my hands smell like liquid wrench even after a thorough wash. Any suggestions? The hex is starting to strip and it's pissing me off
Old 03-21-2007   #2
Re: Seized Ground Control Screw
Which screw are you talking about? can you post pics?
Old 03-21-2007   #3
He is talking about the hex-screw that locks the perch in place.
Old 03-21-2007   #4
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
I got it guys, thanks. I decided to use an old trick I learned in high school where you insert a hex or screw driver bit into a ratchet socket and use the ratchet for extra leverage. Torque power ftw!
Old 03-21-2007   #5
tim
tim's Avatar
Now dont forget to replace that set screw for next time. Maybe put a little antiseize on it.
Old 03-21-2007   #6
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
well you're not supposed to take it out because it won't go back in if you do. I sprayed some more liquid wrench on it and worked it back and forth.
Old 03-21-2007   #7
tim
tim's Avatar
It had to go in at the factory didnt it? If you did strip it out you would have an even bigger headache.
Old 03-21-2007   #8
Speedfreak
Drives: four tires
Why are you messing with it anyways? Changing the height? It looked perfect the way it was.
