Old 08-10-2007   #1
No start
So I was driving in one of the mall of america parking ramps last night looking for a spot, and just as I'm pulling up, I noticed my car started running a little rough. I pushed the clutch in, it died, and now it won't start. I've got spark and I can hear the fuel pump running as the car is turning over, and can smell fuel in the engine bay. I'm stumped as to why it would be running just fine, die, and not start. Any suggestions?
92 gsx
gm maft
walbro 255
brand new spark plugs
Old 08-10-2007   #2
x-pride
x-pride's Avatar
Re: No start
Hows your timing?
Old 08-10-2007   #3
Re: No start
ECU has new caps? Mine did some funky stuff, and wouldnt start half the time when my ecu crapped out.
Old 08-10-2007   #4
Re: No start
The ecu caps have been replaced once already, but I dunno how long ago. The last time I checked the timing, it was spot on.
Old 08-10-2007   #5
Re: No start
I would throw a spare ecu in if you have one, just to rule that out.
Old 08-10-2007   #6
Re: No start
The only other ecu I have is a socketed eprom with no chip. I'm still waiting on the keydriver chip I ordered.
Old 08-10-2007   #7
Re: No start
I have a kedriver chip I could sell you for cheap, let me know.
Old 08-10-2007   #8
Re: No start
I just got the chip, threw it in the ecu, so I'll go throw that in and see if it does anything
Old 08-10-2007   #9
Re: No start
Bring tools with to check the timing belt too.
Old 08-10-2007   #10
Re: No start
The car is home now, I put the eprom in, still didn't fire. Checked the timing belt, it's just fine. I'm thinking the cam sensor probably took a shit. I was looking at it, and noticed a little bit of oil at the bottom of it.
Old 08-11-2007   #11
x-pride
x-pride's Avatar
Re: No start
Do a compression check next. Before you even start troubleshooting any further. Even if your engine is cold you will still get compression. My brothers car was doing something similar. We did a compression check and it was 60 accross the board. Redid the timing and the car was good to go.
Old 08-22-2007   #12
Re: No start
Ok, The Compression test came out just fine, I don't have a timing light right now, so I can't test that just yet, Put in a new Eprom chip, and the damn thing still won't start. When I connected the new ecu, my logger connected to it just fine. After turning it over a few times, I turned the ignition off, checked a few things, then turned the car back on, and the logger wouldn't connect. The next thing I'm gonna try is getting a timing light, and replacing is the cam sensor. Anyone else have any suggestions?
Old 08-22-2007   #13
Hoffer00
Cantankerous Tank Champion! Fight Man Champion! Go Johnny Go Champion!
Re: No start
Does it try to turn over.
if it does.
it die when you pushed the clutch in.
How new is your clutch/pressure plate.
Old 08-22-2007   #14
Re: No start
It turns over just fine. Clutch disc only has a couple thousand miles, Pressure plate is unknown, but was in good condition when my new motor was built and worked just fine before the car died.
Old 08-22-2007   #15
Re: No start
You say that you have fuel and you have spark and you have compression. Those are the 3 essential things your need, but if your a/f ratio is way off (due to say a bad coolant temp sensor) then it won't start. You said you can hook up your logger, can you check what your temp sensor is reading? those little bastards can go bad and cause a no start condition.
Old 08-22-2007   #16
Re: No start
By saying to check the timing, we weren't talking about ignition timing. You need to check the timing belt timing to see if it is off. There is a good chance you jumped a few teeth on the belt.
Old 08-22-2007   #17
Re: No start
I'll double check the timing belt timing if it's not raining tomorrow. The logger connected the first time I tried it with the eprom, but after then it wouldn't connect. So unless it decides it doesn't wanna be a bitch anymore, I can't do too much with that.
Old 08-23-2007   #18
Re: No start
Your logger won't connect? Hmmm... and you know for sure the new ECU you put in was a known good ECU?
Old 08-23-2007   #19
Re: No start
I had this problem from time to time with my 2G where moisture would get into the MAFT box and it would basically not work at all. Try hooking up a standard MAS and see what happens.
Old 08-23-2007   #20
Re: No start
My MAFT box is inside the car, so I dunno how it could have gotten moisture in it. The ecu I got came from a running car (or so I was told). Brandon, what you said about the coolant temp sensor seems like it might be right, When I turn it over, een if it's just for a couple seconds, the plugs are prety wet. So that leads me to believe it's either dumping in way too much fuel, or there's just not enough spark to ignite it (weak coil).
