Old 09-03-2008   #1
lucasoil4u
Drives: talon tsi evo 3 25psi
Smile compressor surge
1996 eagle talon tsi, evo 3 big16, 1g blowoff valve, fmic, external dump, 3 inch exhaust, apexi neo, greddy boost controller, greddy turbo timer, walbro 255lph. I recieved this car from someone and when ever you turn the boost over 13 psi it bucks and coughs and spits... do you think that i need bigger injectors i dont know what is in there now. let me know what you think .
Old 09-03-2008   #2
Re: compressor surge
Why does your info under drives say "Talon TSI evo 3 25psi if you cant boost over 13?
Have you checked for boost leaks? 13 psi "shouldnt" be hitting fuel cut. i would check for leaks. Also check your settings on the neo, and what are you using for logging? Suggest getting a logger.
Old 09-03-2008   #3
Apexi Neo doesn't work right on DSMs or any Karmen cars. It could still use 550cc injs, a boost leak test and a tune though. It might need new spark plugs and/or have a boost leak. But there is a known problem with the Neo on DSMs, Evos, 3000GTs, etc and Apexi has been trying to fix it.
Old 09-03-2008   #4
lucasoil4u
how do i do a boost leak test???? im on like the 3rd set of plugs in 3 days... it was in the car when i got it. what else would be affordable like that?
Old 09-03-2008   #5
lucasoil4u
oh and 99gsx it will go to 28 spitting and coughing.
Old 09-03-2008   #6
25-28psi on pump gas spitting and coughing...might want to start shopping for a new engine LOL
Take the above advice by doing a boost leak test then replace that Neo with an older version S-AFC and get yourself a professional tune.
Old 09-03-2008   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
DSM LINK!!! Boost leak test, tune!!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 09-03-2008   #8
cmspaz
Walls need hugs too
cmspaz's Avatar
http://www.vfaq.com/mods/ICtester.html
^^There's your boost leak test, Ryan^^
What you've got sounds like fuel cut to me, though... So I'd run it at 13 until you can get an AFC that'll work, or preferably, DSM Link.
Originally Posted by Trogdor
Old 09-03-2008   #9
You also might wanna figure out which injectors are in the car now before you go buying new ones.
Old 09-03-2008   #10
95talonracer
95talonracer's Avatar
Boost leaks, bad or no tuning. You NEED a wideband to tune and some way to see knock. Good luck.
Amsoil Dealer
Old 09-04-2008   #11
cmspaz
Walls need hugs too
cmspaz's Avatar
Actually, I was talking to a longtime DSM'er today, and he stated that his GF has a Neo on her 2G, and it works fine. He said it was more than likely a wiring issue than an actual issue with the device itself.
Verify that you clipped the right wires and put them in the correct places.
Old 09-04-2008   #12
Spyderturbo007
Spyderturbo007's Avatar
Albatross Overload (Yeti 4) Champion!
Drives: 1997 Eclipse Spyder GS-T
It depends on the serial number of the Neo. Initially there was a linearity flaw surrounding the airflow corrections. Things become very erratic with the Neo's output and can cause major damage. If the last four digits of your serial number are below 13800 and there is no Karmen compatibility sticker on the back of the unit the unit contains the programming bug.
If you have one of the problematic units, you should remove the Neo and reconnect the MAS wire at pinout #90. Keep in mind, that if you are running larger injectors, you'll need to swap back to stock until you get the Neo fixed. Let me know if you need a copy of the form you have to send back with the Neo.
Spyderturbo007 is offline   Reply With Quote
Old 09-04-2008   #13
That was a pretty good first post. Welcome to the site.
Old 09-05-2008   #14
lucasoil4u
lots of boost leaks gonna try to run it again and see what it does. also gonna ry to get the apexi reprogramed. thanks a bunch..
Old 09-05-2008   #15
cmspaz
Walls need hugs too
cmspaz's Avatar
np, man.
Correct me if I've got any bits of this wrong, but here's what I got from the short conversation we had when I picked up the headlights... You had all of the listed goodies on the burgundy talon, which was then totaled, so you swapped them over to the green one, and you're now having problems. Correct?
So wouldn't that point more toward a wiring issue than a programming or version issue?
Old 09-05-2008   #16
lucasoil4u
whole different motor and setup the purple one was stock tuning no goodies on it at all. exhaust and intake and thats it. thats all that it had. bought the car from someone and now its having problems or has always had the problems.
Old 09-05-2008   #17
cmspaz
Walls need hugs too
cmspaz's Avatar
Ah, gotcha.
Old 09-05-2008   #18
lucasoil4u
will the computer from an automatic 2g work in a manuel one? the automatic one is chipped.
Old 09-05-2008   #19
lucasoil4u
so when you put in the neo u just dont tap into the wire cause that is how it is done....
Old 09-08-2008   #20
Spyderturbo007
It doesn't matter if it's a manual or auto when dealing with a 2g, only with a 1g. The 1g automatics ran 390cc injectors as opposed to 450's so they aren't interchangable.
