Old 12-12-2008   #1
kittay
Lady dsmer
kittay's Avatar
Drives: 91 GSX, 91 TSi, 91 TSi
Trannys suck
Esp the dead ones.
I got my tranny from the BC apart as well as my 2 parts trannys.
Verdict:
Evo shift forks are good.
Sliders are thrashed
Bearings are done for
Gears are trashed
All 3 center difs are done for.
One has 2nd gear that looks ok, but I don't want to risk it with high rpms.
So I'm going to have to send the center dif in as a core, and get a 4spider. Ordering 1-5th gears, new hub sliders and bearings.
This is expensive. OMG. wow.
TRE seems to have some things cheaper, and Jacks Transmissions has a few things cheaper.
Anyone doing their trannys themselves, any advice?
kittay is offline   Reply With Quote
Old 12-12-2008   #2
joem
Drives: 1991 Talon awd auto
Re: Trannys suck
I have a evo 3 trans. if you need parts
Old 12-13-2008   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: Trannys suck
Take your time. If your not sure about something, research until you are. If you want it to last it's going to cost money.
Old 12-13-2008   #4
kittay
Lady dsmer
kittay's Avatar
Re: Trannys suck
The only thing I'm not too sure about is for the center dif.
I really don't want to do welded, esp if I want to DD it or take it on a trip. So I was thinking 4spider, just unsure on how well that'll hold up
Old 12-13-2008   #5
Re: Trannys suck
Damn I was thinking this thread would be about chix with dix.
Old 12-13-2008   #6
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Trannys suck
And yet you came in anyway...
Originally Posted by Trogdor
Old 12-13-2008   #7
MustGoFaster
Re: Trannys suck
The 4 spider should be just fine. I've never heard of anyone breaking one, have you?
Old 12-13-2008   #8
Re: Trannys suck
Taking the tranny apart is pretty straight forward, if you are afraid you might forget where something goes or how it looks then take pictures as you go along for reference, and also label your parts with a good desciption of location or orientation. The only thing I was confused about reassembly was setting the preload shims and how to check them.
Thats why I just had Shep give me a stage 3; 4 Spider, Chromoly forks, etc.
Old 12-13-2008   #9
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Trannys suck
If you do take pictures, posted them. I have been wanting to rebuild my tranny for a while now. Maybe this would be motivation.
Old 12-13-2008   #10
Re: Trannys suck
Do a 4-spider, i've never heard of anyone breaking one.
I have a welded center, and i fucking HATE IT.
Old 12-13-2008   #11
Re: Trannys suck
I had a welded diff from shep and one that was welded by john at LSE, he welded the shafts together as well which I was inform was mostly done on high hp/tq cars 600+.
Welded diff from shep felt fine I actually liked it the one tougher welded one sucked as it was locked hardcore just getting in and out of the driveway the shep one not so bad.
Old 12-13-2008   #12
Re: Trannys suck
Welded center diff is not for a street car. Also I do not see how the Shep welded diff would "feel" any different, if its welded it will provide a 50/50 split no matter how good or bad its welded.
~john
Old 12-13-2008   #13
Re: Trannys suck
~john
Well with the shep one, I had a hard time telling if it was welded, couldn't tell until 2 turns of the wheel, your one you could tell just trying to roll down the driveway and turning the wheel maybe 1/2 a turn.
Old 12-13-2008   #14
MustGoFaster
Re: Trannys suck
Did you have different tires on the car? Change anything else? Welded is welded, no rotation allowed.
Old 12-13-2008   #15
Re: Trannys suck
Nope nothing different.
Nick was with me too and he could tell it was welded, then I explained to him the differences between the two, Sam agreed with me in the way it felt.
Old 12-13-2008   #16
kittay
Lady dsmer
kittay's Avatar
Re: Trannys suck
Lol.. I got the tranny out of the black cherry all torn apart and the 2 spare trannys all torn down.. It was so surprising on how simple it was!
I really don't think I'll do welded center dif, just because of DDing it and the 255 wides.
I'll try and get some pics. But doubt I'll be getting any motivation until I get new gears/ syncros/ sliders/ bearings/ center dif
Old 12-14-2008   #17
Re: Trannys suck
Aaron, it sounds like the Shep one is a 4 gear, not welded. Like they said, welded is welded. I have a 4 gear in my car from Shep.
I would get a junk yard tranny so you can at least get the 3-5 gears. How can ALL of the gears be bad in all 3 trannies? That just doesn't seem right. Be sure to check Shep out for trannies too. He also usually has a decent amount of used parts on hand too.
Old 12-15-2008   #18
kittay
Lady dsmer
kittay's Avatar
Re: Trannys suck
Some of the gears looked OKish, but nothing I would trust, esp when building a tranny.. Might as well do it right.
But the sliders had started to round the teeth of the gears.
