Old 02-15-2009   #1
95tsi
95tsi's Avatar
Drives: a pos
help
Saw a bit of an oil leak, so I pulled the oil pan off. Saw this stuff lying inside... I dont know what it is. Any help would be greatly appreciated. Thanks.
Old 02-15-2009   #2
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: help needed!!!
Looks like bearings out of a turbo. Blown up any turbos?
Old 02-15-2009   #3
95tsi
95tsi's Avatar
Drives: a pos
Re: help needed!!!
would the bearings fall through the oil return to the pan, without any other issues??
Old 02-15-2009   #4
Re: help needed!!!
The turbo probably wouldn't be feeling to good. You should probably take the engine completely apart and clean out all the oil galleries and passageways.
But you could probably get by with a couple oil changes in rapid succession with new filters.
Old 02-15-2009   #5
Re: help needed!!!
Your username is 95tsi....has the T25 on your car been replaced ever?
Old 02-15-2009   #6
95tsi
95tsi's Avatar
Drives: a pos
Re: help needed!!!
No why? The car only has 175xxx on it, would that cause early turbo wear? No, I have a dark green 2g with an E316g on it(360awhp). Its been at DB before, just working on a 6 bolt swap on it, using a motor I pulled from another car. I'll have to get some pics of the turbo which came on this motor...
Thanks for the help to ID the parts. I think I got everything cleaned out and in good shape. The turbo going back on only has 2000mi on it so I should be good for another year. Thanks Again!!
Old 02-16-2009   #7
Re: help needed!!!
Well you wouldn't be the first person; how long have you had the car? It could have happened long ago. Some threads that you might wanna read for cross reference:
http://www.mitsustyle.com/forums/sho...arings+oil+pan
Old 02-16-2009   #8
95tsi
95tsi's Avatar
Drives: a pos
Re: help needed!!!
I've had the 7bolt in my car since it came from the factory, never had an issue with it. Until, it dropped the balance shaft belt last Sept. Checked out a car for sale(from here) and it had a built motor in it with low miles on it. Bought it and brought it home, turbo was junk and it ran like crap due to many issues. Swapped motors, turbo setups, and a few other things.
Everything I noticed looked good on the underside, no signs of damaged bearings or seals. I should be back up and running, if all goes well, by the end of the week. Then hopfully get to MAP and beat Aaron on the 16g dyno numbers.
Old 02-16-2009   #9
Re: help needed!!!
Originally Posted by 95tsi View Post
... turbo was junk...
I think you figured out where that stuff came from...
Old 02-16-2009   #10
95tsi
95tsi's Avatar
Drives: a pos
Re: help needed!!!
sure did, you can delete or close this thread. Thanks.
Old 02-16-2009   #11
Re: help needed!!!
Holy crap dave! Good thing you caught it before anything bad happened to it!
This kinda stuff makes a guy want to triple check everything.
I Better get the first ride in this thing once its tuned again too!
Old 02-23-2009   #12
Cammaxon
Brian Spilner called...
Cammaxon's Avatar
Drives: RR EVO Viii 493AWHP Spilner Mobile(sold)
Re: help needed!!!
Your car is spitting out money and you're going to call it a problem ? that's 25 cents you didn't have yesterday! I say keep this cash cow flowin'!
Cammaxon is offline   Reply With Quote
Old 02-25-2009   #13
johnson
johnson's Avatar
Drives: 90mitsu
Re: help needed!!!
^^ good one!! haha
