Old 03-29-2009   #1
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Upper controll arm piviot bolts.. bad?
So this moves back and forth pretty bad.. will a new bushing kit fix this??? I was thinking of getting a poly bushing kit from MAP. or should I just replace with oem..... I am correct in assuming this shouldn't move when I pull on the upper control arm.
here's video http://s24.photobucket.com/albums/c2...ent=DSM014.flv
Old 04-03-2009   #2
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Upper controll arm piviot bolts.. bad?
Okay I tried to tighten the nut in the bottom of the Ingalls Front pivot bolt & it's tight but still slips. Is there a place that sells only one side of these or do I need to buy a whole new set??
