Old 05-12-2009   #1
96GSXMN
Drives: Delete my account
Ok I have a where to go question. Radio install?
Ok I have this Pioneer dvd flip screen radio that I would like installed in my car. I have hooked up regular radio's in my cars but I have never hooked one of these flip screened radios and I really dont want to take the chance of screwing it up. I would also have to have the parking brake switch deleted (I already bought the cheat box for it) So is there any place I can take this to get installed in my eclipse???
96GSXMN is offline   Reply With Quote
Old 05-12-2009   #2
Re: Ok I have a where to go question. Radio install?
i have done a ton of them. there is nothing diffrent from the install for it over a std deck
Old 05-12-2009   #3
96GSXMN
Oh really, cool it just has that extra box that all the wires go to and I kinda got intimidated lol. Am I going to be able to run the factory amp? Thank you.
Old 05-12-2009   #4
Mine didn't have any extra box. Is that for an external gps/navigation unit or something? Just don't hook up the parking brake wire and it will never be disabled. I'd also just use the internal amp on the deck.
Old 05-12-2009   #5
the exrta box could also be the brain box. you can wire in the factory amp. you will just have to wire it in with the deck wiring
Old 05-12-2009   #6
cmspaz
Walls need hugs too
cmspaz's Avatar
Amp usually requires a separate harness from what I've seen, generally uses the RCA ports as opposed to wiring in through the main harness.
Originally Posted by Trogdor
Old 05-12-2009   #7
jrohner
jrohner's Avatar
Just buy the Metra harness that eliminates the stock amp.
Old 05-13-2009   #8
cmspaz
Walls need hugs too
cmspaz's Avatar
You're kidding, right?
The amp eliminator harnesses lose the tweeters and destroy sound quality. If you like what effectively sounds like tweeters behind you and treble-less speakers on the doors, with no workaround, be my guest and do it. Unless you're installing another amp, that's the worst possible solution.
Old 05-13-2009   #9
The DVD deck in my car has a separate box too. Super easy to install, not any more difficult than any other stereo I've ever done. The head unit for mine is just a spot to hold the screen, controls and to put the DVDs and CDs. The box controls everything. I just located that under my back seat and ran all the wires under the center console.
Old 05-13-2009   #10
311evo
311evo's Avatar
Just continue using the factory amp, or re-wire it all.
Old 05-14-2009   #11
I vote rewire. But that's easy for me to say because the previous owner did all that for me, lol.
