Old 09-08-2009   #1
97gst_2007
Drives: 1997 Spyder GSX
quick question about a 20g
i have got a 20g turbo on a 6 bolt swap and was wondering how much boost the 20g will put out. this way i know if i should built the internals up like massivly or not. get back to me asap. because it is being put together tomorrow
97gst_2007 is offline   Reply With Quote
Old 09-08-2009   #2
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: quick question about a 20g
With a good tune you should have no problem maxing out a 20g on a healthy stock 6 bolt I would think. Someone with more experience should chime in though...
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-08-2009   #3
What kind of fuel? on pump gas, ~20psi is about all you want to run w/o a nice tune with a good tuning setup (dsmlink or alt, not just a s-afc).
On some sort of high-octane, with a good tune, you could probably weld the wastegate shut and the bottom-end should hold together. Another 2G 6-bolt swap on here has been making 500-600whp on his this summer.
Old 09-08-2009   #4
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
It's all in the tune
Old 09-08-2009   #5
97gst_2007
ok well how much to get a DSM link or an ESM link into the car then would you know or where i can get one?
Old 09-08-2009   #6
You gotta try just a *little* bit:
http://www.google.com/search?q=dsmli...ient=firefox-a
Result #1 Get it from the source.
Or, put an evo8 ecu into your car. Either way, get it tuned. LSE doesn't exist anymore, but there are other vendors on here that can help you out!
Old 09-08-2009   #7
97gst_2007
the engine is a Built 6 bolt done by LSE roughly 8k miles
-Dejon frount mount and hard piping
-Greddy Type S
-Forced Performance 4 inch Intake
-HKS Filter
-Hallman MBC
-NGK plugs and wires
-APR Headstuds
-SS oil lines
-functioning cruise control
-New front o2 Sensor
-Brand new Battery
-Single Slim Radiator Fan
-AC Removed
but i do not know what kind of build is into the motor i am talking to niterydr to see if he can tell me what he actually put into the motor so that way i can see if i can run more boost or do i have to build the motor again.
Old 09-08-2009   #8
97gst_2007
the turbo is a
-Forced Performance 6SL2 20g Turbo set at stock boost level
-SLS External wastegate o2 housing (open dump)
-Tial 38mm wastegate (1 bar spring)
-Apexi N1 downpipe
-Apexi N1 Catback Exhaust
Old 09-08-2009   #9
97gst_2007
i know that LSE does not exist but i know who owned it so i am talking to them about the motor is all. and does anyone know where i can get a used DSM Link? i the laptop already just need the system and the software is all
Old 09-08-2009   #10
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I know of at least one but there still might be 2 that are currently available in the classified section. Try using the search button.
7/25/09
Old 09-08-2009   #11
97gst_2007
i did not know that you could use an evo 8 ecu otherwise i would have put it in when i had it. i sold it but hey you learn new things. would it still need to be tuned even after the evo 8 ecu is installed?
Old 09-08-2009   #12
Yes.
Try the classifieds section:
http://mitsustyle.com/forums/forumdisplay.php?f=78
Old 09-08-2009   #13
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
since he has a 95, he could possibly just get a chip?
Old 09-08-2009   #14
As long as he has an EPROM ECU, yes Shane could burn him a custom chip also.
Old 09-08-2009   #15
What is your current fuel system? Are you running bigger injectors and an upgraded pump? or stock injectors? Your fuel system, tuning system, and the type of fuel will be the deciding factors in how much boost you can safely run. Your bottom end will be able to handle whatever the 20g can throw at it.
Old 09-08-2009   #16
Quick answer: A billion
The 6 bolt block can hold quite a bit of power when properly tuned.
