Old 11-23-2009   #1
jto92tsi
Drives: 92 tsi awd
1gb shift lever
I need the lower shift lever for a 1gb. Then I hope my talon will move lol.
jto92tsi is offline   Reply With Quote
Old 11-23-2009   #2
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: 1gb shift lever
The lever on the tranny? or the shifter itself? What is a shift lever and why is it 1gb specific? I have a short shifter... and some shifter cables from a 93.
'04 Honda Ricer: stock
Old 11-23-2009   #3
jto92tsi
Drives: 92 tsi awd
Re: 1gb shift lever
Just the lower lever on the trans. I have a 92tsi awd with a 90 trans. Mark told me that if I swich the levers with a 1gb it will work. I hope it does I don't want pull the trans again.
Old 11-23-2009   #4
Re: 1gb shift lever
You have to take the case apart to swap arms, it's much easier to swap cables and shifter assy.
Old 11-23-2009   #5
Drives: 98 iVTEC
Re: 1gb shift lever
I thought so too but if he knows another way, more power to him. Good luck with it. I've also seen other people drill a hole in the arm to make it 100% perfectly straight or whatever exactly needs to be done.
Old 11-23-2009   #6
jto92tsi
Drives: 92 tsi awd
Re: 1gb shift lever
It not hard to take it off. There is a tapered pin holding it on. You just have to make sure you pound on the small end of the pin.
