Old 12-01-2009   #1
GnArKiLl
GnArKiLl's Avatar
holset question
what size is the thread for the oil feed on an hx35? i cant find it anywhere.
03 Evo VIII
95 Talon AWD-wire tuck,6bolt,holset powered,E85
95 Nissan 240sx KA-T
93 Eagle Talon-5spd swap,wire tuck..SOLD
Old 12-01-2009   #2
Re: holset question
12 x 1.5
Old 12-01-2009   #3
GnArKiLl
GnArKiLl's Avatar
Re: holset question
im trying to find a fitting that is 90deg with a 4-an on one side... and i cant find anything
03 Evo VIII
Old 12-02-2009   #4
Re: holset question
That might be tough.
Old 12-02-2009   #5
Re: holset question
Yeah that might be tricky. Something to consider is juts getting a straight adapter fitting, and using that with a feedline that has a 90* -4an end on it. That's how mine is setup.
Old 12-03-2009   #6
GnArKiLl
GnArKiLl's Avatar
Re: holset question
that would work but i have to run an oil restrictor at the turbo. i think it will be to tall.
03 Evo VIII
Old 12-06-2009   #7
Re: holset question
I have an "Extreme PSi" oil feed line from the oil filter housing with a holset adapter fitting. I use an FP journal bearing restrictor.
I have the 90 degree fitting on the OFH, then the FP restrictor/filter attached, then the -4an line which goes to the a built in 90, then the M12x1.5 adapter on the turbo.
Old 12-02-2009   #8
Re: holset question
same here, it will be ur best bet
Old 12-02-2009   #9
Re: holset question
I have a m12x1.5 to -4 an fitting. my oil line has a 90 built in.
Old 12-02-2009   #10
The 92 Laser
The 92 Laser's Avatar
Drives: Turbo Miata
Re: holset question
Go on Dsmtuners they have over like 2000 pages on Holsets. Including a specific one on how to run the oil feed. I plan on getting one when i get home from Iraq. Sorry dont mean to refer you to another site. I just know they have a lot of stuff on there about Holsets. Awesome turbos, put up numbers when she gets dynoed. Heres a link
http://www.dsmtuners.com/forums/turb...-part-7-a.html
The 92 Laser is offline   Reply With Quote
Old 12-06-2009   #11
Re: holset question
I did the nitrous line deal, I have a gauge at home so essentially I will be able to tune my oil psi at the turbo
Old 12-06-2009   #12
jrohner
jrohner's Avatar
Re: holset question
I bought a banjo fitting on ebay. It works perfect. The hole in the banjo bolt is .060, so it's a restrictor already too, if you want more pressure drill it out a little.
