Old 03-31-2010   #1
stikx
Mr -
FIC 1600cc injectors, AFPR + install kit
FIC 1600cc injectors: SOLD!
MAP AFPR Install Kit with Fuelab Regulator (Evo 8 & 9) Brand new never used: $160 (I think you just need to change one fitting to make it work with dsms?)
Old 03-31-2010   #2
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Re: FIC 1600cc injectors, AFPR + install kit
Injectors work with a DSM?
How many miles on them?
What model are the injectors?
Old 03-31-2010   #3
stikx
Mr -
I'm pretty sure the injectors work on DSM's. Not sure on the model or the mileage. It came with the car, which has under 30k miles.
Old 04-01-2010   #4
turboimports
I'd have to be sure they are 1600cc or larger.
Old 04-02-2010   #5
stikx
Mr -
xl3e-c9a. I searched it, came up with bosch 160 lb/hr injector.
280150846, this number is on the other side of the injector.
Old 04-07-2010   #6
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Bosch
0280150846 - 1650 cc -white tops
( 14mm top, 16mm bottom )
## unusual 4.5 ohms
is reputedly similar as the earlier blue
[ but alcohol, CNG and LPG vapour compatible ]
( some tests rate them as only 1300 cc )
the blue is a ford USA motorsport item, hence the indy term
the white is a specialised alcohol injector, with heavy pintle , a little slower than the rest
Ford PN:
Ford XL3E-C9A / Ford XL3Z-9F593A
motorcraft - MICM4980
Information taken from 3si.org. User that posted info is donniekak. Heres a link to the thread: http://www.3si.org/forum/f1/guys-wan...ectors-468684/
Old 04-06-2010   #7
turboimports
Here seems to be the information on them.
http://www.dsmtuners.com/forums/bolt...injectors.html
I don't know if it's what I want to do. So I'll keep on debating on it.
Old 04-06-2010   #8
way2fastalon
IS Broken :-/
way2fastalon's Avatar
are these the ones where you have to modify your fuel rail ?
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 04-07-2010   #9
stikx
Mr -
Not sure. Maybe post up on tech section?
Old 04-07-2010   #10
stikx
Mr -
new low price
