Closed Thread
Old 06-07-2010   #1
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Thumbs up Modern Automotive Performance
Well here is my story, I'm sure I'll be flamed for it but whatever.
I ordered a 2.3L 6 bolt short block and new OEM oil pump last summer. It was supposed to be a simple build, well 2-3 months of waiting because they sold me a set of rods that they didn't even have in stock and didn't tell me about it for along time. So anyway I picked the motor up in the packaging that they put it in and that's where it sat until a week ago when it was ready to be installed.
The directions I got with it were to tighten the oil pump housing to 15ft pounds and then trim the edge of the gasket that will squeeze out. When I set my torque wrench to 15 it clicked instantly, so I turned to 17 and clicked again, then to 20 and 25, same thing. I noticed that the gasket had already been trimmed as well.
So 20 miles into the break-in oil just poured out of the timing cover, 2.5 quarts in a hundred feet it took me to get stopped and turn the motor off (I turned it off when I first saw the oil, I break-in with no hood as well to "check for leaks"). Well after a week of tracing the leak/s, I finally found the big problem.
First leak was detected when I took the timing belt off because it was covered in oil and needed to be cleaned. The leak was on the lower bolt hole of the belt tensioner. I knew this was not right so I put copper crush washers on either side of the bolt and it was fixed.
Second leak took a lot longer to track down because every time I'd pressurize the system with the drill it would take awhile to leak, but eventually I ended up pulling the gear off the pump and sure enough the seal was messed up (not blaming MAP) and the shaft had play in it.
I called MAP and told them of the problem and they decided that there are too many variables (blaming me) for them to have any part of the responsibility.
A little back ground on me and the car (91 AWD Talon): I graduated from the Automotive Service Program at Northwest Technical College with a 4.0 GPA in 1.5 years. I have been a machinist for the past 3 years and know that everything must be kept 100% clean prior to and during assembly, so I have a clean room to do so. I've worked on countless Talons and an Evo or two in the last decade and never had an issue that would be something to be blamed on me.
The reason for the motor being purchased was a spun bearing on the last built motor from SLS that lasted 3000 miles. So when I ordered the new motor I also brought the head down to be fully disassembled and cleaned by them as well.
The turbo was shot so I got a brand new one from Precision with brand new Earls pre-filter kit. Brand new oil filter housing, and any oil lines....long story short on the motor anything that touched oil was purchased new and kept packaged until assembly.
So I took pics of the damage to the oil pump and gave them a call, they told me that there are too many variables so they will accept zero responsibility and all they can do to "help" is to order me up a new oil pump (at my cost).
I thought they were good guys from what I hear on here and on the street. Also when I was ordering the motor they told me how they stand behind every build and if anything were to ever go wrong (which they said they have never had a problem with anything they've touched) that they would do anything they could to help me out. Well big talk and no action when the time came.
Edit: I spoke with Chris this morning, the conversation started out pretty heated. After about 30 minutes of back and fourth we both came to an agreement and he is working to try to help me out. Any of the previous shops I've dealt with in the past decade, besides AMS and ExtremePSI (DSM Summit not really a shop), have screwed me over in the past and have never came back to try to make things right. So as of right now I will wait and see how things play out and if they do right by me I will give them more chances in the future.
I really like to see "local" business (by which I mean Minnesota, not local to me because I'm four hours away) succeed and support them when I can.
That is all for now!
Mwolf83 is offline
Old 06-07-2010   #2
Mwolf83
Re: Modern Automotive Performance
Pics of the damaged pump
ID:	10217   Click image for larger version
ID:	10218   Click image for larger version
Mwolf83 is offline
Old 06-07-2010   #3
This should have been in the good guy/bad guy section.
Anyways, I had a similar situation with MAP last year with a transmission I bought from them, the car only turned the front wheels after installation, then the blame game ensued. No discount, refund, or return because it was a used part that "worked perfectly" when it left their shop and it was "impossible" for them to warranty used parts. Buying a part that never worked in the first place, then getting refused a refund, discount, or return will leave anyone with a pretty sour taste in their mouth.
Last edited by goodhart; 06-07-2010 at 08:41 PM.. Reason: edited to better describe the situation
goodhart is offline
Old 06-08-2010   #4
v8klla
v8klla's Avatar
Correct me if I'm wrong but wasn't their an issue with either missing dowel pins or shifter bushings that was causing your problem? Either way, that transmission was taken from a perfectly running car just days before, and again we had no hand in the installation of the part, what would you suggest to be the proper course of action?
I bought a oil feed line for my talon. I got it very quick I was happy at first. So I went out to the garage to install the line. The oil line was to short and the fittings were wrong. So I returned the line thinking that they could get me the correct line just a fast they got me the wrong one. It took about 3 to 4 weeks. They said it wasn't there problem. It is there problem if you are sell parts that you are getting for another company you should make sure the shit is right.
I simply don't believe that anyone here said "It's not our problem" that's just not how we do business. However, we do heavily rely on other companies in some scenarios like this, if there was a backorder or something out of our control I don't know what else we could have done to rectify the situation quicker for you We would have happily refunded you in full so that you could have sourced the line elsewhere if you desired...
Chris Carey, President
P: 763-545-3800
E: chris@maperformance.com
v8klla is offline
Old 06-08-2010   #5
Shifter bushings which were replaced by Alex and the car still failed to turn the rear wheels. Not sure what either dowel pins or bushings have to do with making wheels turn, but whatever. The car DID run perfectly, just only turned the front wheels.
I also drove the car down there, then was told it was not drivable for the way home. Not sure why that was either. That was also the second time I made time out of my schedule,the first was the time I had a pickup time arranged, only to see the car in pieces in the back when I got there and not one mechanic in sight.
As far as the proper course of action, make me an offer.
goodhart is offline
Old 06-07-2010   #6
Mwolf83
Yeah sorry I though I had clicked good/bad guy.
Mwolf83 is offline
Old 06-07-2010   #7
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Wow I cant believe they wont step up and give you a hand...
Sorry for your loss. I hope it works out for ya man!
t-revzr is offline
Old 06-07-2010   #8
Mwolf83
Thanks dude.
Mwolf83 is offline
Old 06-07-2010   #9
I moved the thread. Good/bad guy feedback section is for individual member feedback only, our sponsor shops have their own sections for a reason.
Kracka is offline
Old 06-07-2010   #10
Mwolf83
Yeah, and when I clicked a previous good guy/bad guy thread and then clicked something to start new I thought I was clicking on same section. Sorry again.
Mwolf83 is offline
Old 06-07-2010   #11
That does sound kinda crappy Not that this matters, why didn't you try building the engine yourself?
sleepydsm is offline
Old 06-07-2010   #12
Mwolf83
Because I wanted a tested and true 1000awhp motor that will stand the test of time. When I first called to order it I had narrowed my build possibilities to AMS, Buschur, and MAP (not as well know). I had done business with AMS in the past (not bad people) and had spoken with David Buschur and he acted like a real prick on the phone. So I made a call to MAP and they sounded amazing over the phone and have had friends that do business there and they had nothing but good things to say.
So being that they were more local than the others and the fact that I wanted to support a "underdog" business to give them a chance.....
Mwolf83 is offline
Old 06-07-2010   #13
mlomker
*Resting In Peace*
mlomker's Avatar
That's how you know you're talking to the right guy.
mlomker is offline
Old 06-07-2010   #14
93gtpeater
Drives: cbr 1000rr repsol
Sorry to hear about the bad expierence. That would make my stomach turn. I bought a oil feed line for my talon. I got it very quick I was happy at first. So I went out to the garage to install the line. The oil line was to short and the fittings were wrong. So I returned the line thinking that they could get me the correct line just a fast they got me the wrong one. It took about 3 to 4 weeks. They said it wasn't there problem. It is there problem if you are sell parts that you are getting for another company you should make sure the shit is right. Did they offer a discount on the new oil pump? DB performance is the place to go.
93gtpeater is offline
Old 06-07-2010   #15
Mwolf83
Yeah I love DB and that's where I get all my tuning done, Shane is the man, he has been doing my tuning since the days of Elite.
I've had the same thing happen with lines being the wrong part before from ExtremePSI and when I call them up they say don't bother returning it and then they overnight me the correct parts at no cost to me. I try to get all my parts possible from them, I've spent $15k over the years at ExtremePSI and have never had one bad experience in the 50 or so dealings.
Yes MAP did offer to get me the new pump at cost, and when I asked if it would be at my doorstep tomorrow when I first called them they made it sound like it wouldn't be a problem. But upon them calling me back to give me the bad news about how they're not going to help me out in anyway except to sell me a new pump at cost, but they wont know when I'll get it.
Edit: See first post edit.
Mwolf83 is offline
Old 06-07-2010   #16
b00sted_spyder
+1 for Extremepsi. I do most of my shopping through them. They have the best prices, fast responses through email, and fastest free shipping.
b00sted_spyder is offline
Old 06-07-2010   #17
That front cover was way too tight if it was over 30 ft/lbs, unless your torque wrench is way off. That could possibly cause your problem with the oil pump gears eating into the case.
And I'm a bit stumped on the lower tensioner bolt, that sure shouldn't have any oil coming out of it.
Goat Blower is offline
Old 06-08-2010   #18
Mwolf83
Yes you are totally right that it shouldn't have been tightened that much, which is why I took it off and got a brand new gasket and redid it myself to spec. I guess I forgot to mention that part in my initial ramblings.
Also I still have yet to understand the part about the oil in the bolt hole as well, since the new gasket I put on didn't have any spots in it showing where oil would've went past it into the through hole for the bolt and I also considered the possibility that the block may have been cracked through that hole but that doesn't seem to be the case either.
If I can't solve that mystery then the copper crush washers may just be the fix. We shall see when it goes back together again in a few days.
Mwolf83 is offline
Old 06-08-2010   #19
blackrosenova400
blackrosenova400's Avatar
I dont believe tightening the front cover too tight would cause your oil pump to wear like it did. It would literally have to bend the front cover to be able to cause abnormal wear.
On the other hand tightening the back gear over where the balance shaft came out, too tight, could cause gear endplay too be too tight on the gear and it would chew up as it did.
Show us a pic of the front cover assembly, I want to see if its a legit Mitsu pump.
20g Mafia
blackrosenova400 is offline
Old 06-08-2010   #20
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
In on page 1 That is weird that you depict MAP as people who refused to help you out, the guys I know there do not seem like they would be like that. Who did you talk to?
Setting the cars hardware problems aside; at times a business should eat parts or labor (even if fault cannot be determined) to maintain or strengthen their reputation. At the end of the day in the performance car world that can make or break a business. You cannot tangibly determine how much money would be lost by not keeping a customer happy, but usually the business will lose out in the end if the bad experience is broadcasted through forums and such.
I can't speak specifics but I work in an environment where reputation is everything, and there are seminars I have been to where they should charts of potential loss of losing one customer over a bad experience could cost hundreds of thousands of dollars respectively.
There are times where we know a customer is 100% wrong, but we meet them at a point where they are satisfied and will be a returning customer. Turning your back and admitting no fault (not sure that it actually happened in this case) is very dumb business practice and nothing good will come of it.
If the oil pump cost $300, they don't replace it (even if fault cannot be determined), the next time the customer wants a $3000 motor built, plus bolt ons and tuning undoubtedly they will go elsewhere; at that point the $300 oil pump is trivial.
My opinion. But again until MAP responds it would be ignorant to put blame on anyone.
TheBlizzard is offline
Closed Thread
