Old 11-20-2011   #1
lug nut torque...
Hey, Just wondering what the torque specs are for lug nuts? I have always used 55 ft/lbs, and im sure i saw this somewhere.
Anyways, My winter wheels are steelies, as i know the torque specs may be different depending on the material of the wheel. Anyone know what the torque would be?
Tom
Old 11-20-2011   #2
Re: lug nut torque...
http://www.tirerack.com/wheels/tech/...jsp?techid=107 nm i guess its 70-80 ft/lbs.
Old 11-20-2011   #3
I've always done 100 ft/lbs, especially on steelies.
Old 11-20-2011   #4
I've usually done 100ft/lbs too, by that I mean I just get them really tight and if I feel anal I break out a tq wrench.
Old 11-20-2011   #5
polishmafia
Smells like cat poop
polishmafia's Avatar
Same. On regular alloy rims, 80 is the min I tighten lugs to. Steelies I always torque to 100ft/lbs.
Old 11-20-2011   #6
b00sted_spyder
I only do 80-85lbs. I hate taking off over torqued lug nuts off.
Old 11-20-2011   #7
I do 70 on the WRX and 75 on the X (both within factory spec range).
Old 11-21-2011   #8
Actually, I correct myself. I use number 3 on my air ratchet.
Old 11-21-2011   #9
johnson
johnson's Avatar
Drives: 90mitsu
Haha, i use number 3 too!
Old 11-23-2011   #10
CarPsyco84
CarPsyco84's Avatar
The tighter the less chance they fall off, which I found out, is bad. Dsm's have pretty stout studs, probably have to go over 150ft lbs to start stretching them.
-When in doubt, Moar RPM.
Old 11-23-2011   #11
Worst advice of the thread. Mitsu lists torque specs for a reason.
Old 11-23-2011   #12
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
We use a Doorman book.
Here's a link to the PDF
http://www.dormanproducts.com/docume...pecsMASTER.pdf
Converted to LS
