Old 05-26-2012   #1
johnson
johnson's Avatar
Drives: 90mitsu
more mods,less power...
I upgraded from a
1g maf to a 2g maf,
450s to 880s,
14b to evo316g,
2g exhaust manifold to evo3 exhaust manifold,
TMO stg3 chip to burned chip from shane to comp maf n injectors...
Still running stock sidemount, and stock fuel pump, its running good enough to DD, but really lacking in gittup? Should it be normal til i get fuel pump and tune? Or should i be running a lot better? I dont want to set up a date with shane for nothin? Will i need a fmic? Bigger exhaust? Etc... Before tuning? Im really shootin for the "stock" look!
Old 05-26-2012   #2
johnson
johnson's Avatar
Drives: 90mitsu
Re: more mods,less power...
From this...
To this...
Old 05-26-2012   #3
Fran05
Drives: DSM
Probably running lean with stock fuel pump. Get dsmlink and tune your shit!
Old 05-26-2012   #4
awd laser
awd laser's Avatar
Drives: 93 TSI
Time to invest in laptop!!
Old 05-26-2012   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Not to mention your probably heat soaking the shit out of your smic.
Old 05-26-2012   #6
johnson
johnson's Avatar
Drives: 90mitsu
Wouldnt i be running rich?
Old 05-26-2012   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Get a wideband 255 walbro and a fmic some sort of tuning safc,link, ect
Old 05-26-2012   #8
johnson
johnson's Avatar
Drives: 90mitsu
Im just looking for a fun daily... Not looking to make big power... Yet.....
Old 05-26-2012   #9
johnson
johnson's Avatar
Drives: 90mitsu
So im guessing its not worth going to shane for a tune without a fmic, bigger exhaust, walbro etc...
Old 05-27-2012   #10
I recommend you size every part of your setup to work together.
Your side mount pending boost is hurting the setup, I would say 2.5" exhaust min, and a walbro 255hp is a min for a small project like this. The 880's are big but the chip takes care of that.
I would do a good sized FMIC, exhaust, clutch, fuel pump, link or similar, and get it tuned so you know were your at.
Old 05-27-2012   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
You don't need those parts to make big power. You need those parts to have your car run right.
Pushit is right those size your parts accordingly
Old 05-27-2012   #12
At least do it on the cheap with a stock Evo IX fuel pump, a Supra SMIC, and a fucking air filter so your internals aren't constantly being sand-blasted. Hell, you could even sell those 880's and drop some Evo 560's in there. The smaller the injector you can get away with the better with the DSM ECU's.
Old 05-27-2012   #13
Exactly my thoughts. Assuming you are working within a tight budget, going with used OEM parts from other cars is a great way to keep cost down while still obtaining decent results (e.g. Evo/3kgt fuel pump, supra sidemount, etc).
Old 05-27-2012   #14
johnson
johnson's Avatar
Drives: 90mitsu
I guess when i can get some time away from work n fishin, ill drop that fuel tank for a walbro n go from there!
Old 05-27-2012   #15
Constant_Project21
Constant_Project21's Avatar
Drives: E36
If its a 1g, there's no tank dropping involved. There's a fuel pump access point in the trunk.
Old 05-27-2012   #16
Its your SMIC, they suck and are worthless even on E85 with stock turbo.
Fuel pump is the same even on pump gas I was out of fuel at 10psi.
Replace those 2, tune and re-evaluate.
Old 05-28-2012   #17
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Get rid of that side mount ASAP! My friend with 20 psi on an e16g and sidemount was no faster than my 14b at 15 psi on a small front mount.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 05-27-2012   #18
How much boost? What afr under wot? Get the rest of your parts together and get it tuned, otherwise you're shooting in the dark!
Old 05-28-2012   #19
Sell me this car
Old 04-15-2013   #20
johnson
johnson's Avatar
Drives: 90mitsu
So i got gas the other day, and now my fuel pump shuts off all the time now? It doesnt come back on for at least 5mins?
But it only runs for maybe 30secs or so then sguts off again?
Rewired walbro255
Where should i start? I already swapped ecu and checked connections....
