Old 06-09-2012   #1
DavidPHumes
Drives: Turbo LSx FC RX-7
Clutch/tranny issues... maybe? *RESOLVED*
The other day I noticed that 1st gear was a bit more difficult to go in and reverse is grinding every once and a while. My clutch engagement has always been really low on the pedal and seems to have moved just far down enough where when the pedal is to the floor the clutch is either fully disengaged or partially disengaged - it's inconsistent. If I put the car in first and two step (4,500RPM) the car lurches forward a little (it seems to "surge" a bit but only moves forward an inch or so).
Fluid in the reservoir is full and I followed proper instructions to set the clutch pedal (found the point where the bleeder was blocked off and backed it off a little bit). I don't seem to be loosing any fluid from the slave but there's a hint of fluid on the outside of it (hard to tell if it's brake fluid or oil) but not a lot by any means. The fluid isn't super clean though.
Any thoughts on what might be going on? Only thing I haven't really tried is bleeding the clutch.
Car is a 2G GSX, Shep Stage 4, PTT twin disk, Isuzu slave cylinder, NEO RHD fluid previously, I just changed to Amsoil 75-90 but it feels the same.
DavidPHumes is offline   Reply With Quote
Old 06-09-2012   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: Clutch/tranny issues... maybe?
You might be able to adjust the pedal like on a 1g. Google it or go on youtube and type in clutch pedal adjustment. You should be able to find something.
Old 06-09-2012   #3
Sounds like a dragging clutch, try adjusting the pedal like Paul said
Old 06-09-2012   #4
DavidPHumes
I did. I adjusted it to the point that the cylinder was blocking the path to the reservoir and then backed it off slightly
Basically what the guys explains in this video: http://www.youtube.com/watch?v=vYJxQyjIhUw
Old 06-09-2012   #5
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Bleed it, air in the system can cause engagement/disengagement issue, because its not releasing fully.
Have someone step on the clutch and watch to see if the slave rod and fork moves enough
Old 06-09-2012   #6
93gtpeater
Try bleeding the system. you might have a weak slave or master cylinder.
Old 06-09-2012   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Mine did the same thing at the track never figured out why. My 2 step was at 6200rpm and as soon as I hit 6k it would start to move forward. I don't remember exactly what I did to fix it but I know I replaced a few things and it went away. But I solved the issue at the track by holding the e-brake.
I replaced the line master to slave braided line and also got an extended rod.
Try bleeding it first though. That might be the issue
Old 06-10-2012   #8
DavidPHumes
Alright, going to try bleeding it today. The only reason I didn't do it yesterday is because I didn't have a buddy
I'll report back...
Old 06-10-2012   #9
DavidPHumes
I'll give you guys a few guesses as to what it was. And no, it has nothing to do with the slave/master. I will actually PayPal someone $25 if they can guess. If you're my Facebook friend you're automatically disqualified.
Old 06-10-2012   #10
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
tranny was pushing away from the block? Or other words the bolts were loose on the block. Either way glad you fixed it and it probably was a free easy fix since nothing is open today and by the sounds of it you got it fixed.
Old 06-12-2012   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Damn Im good!!! Do I win $25 LOL if so here my paypal
married.with.kids@hotmail.com
let me know if you need a dowel pin or 2 Im sure I could part with a few.
Old 06-10-2012   #12
Nice that you fixed it. But not sure other than maybe slave was loose? (not bolted down)
Old 06-11-2012   #13
DavidPHumes
All but 1 tranny bolt were COMPLETELY missing, thus causing the transmission to separate from the motor.
Whoever put it in last didn't use thread locker and probably didn't use a torque wrench either.
I actually still haven't gotten it fixed as I ran out of time, but I grabbed a loaner car and will get it done tonight after work.
Old 06-12-2012   #14
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Halon knows how to fix it.
Converted to LS
Old 06-11-2012   #15
Glad its at least a cheap/easy fix.
I've never used thread locker on tranny bolts and never torqued them down to spec either. Just get them as tight as you can has been my torque value haha
Old 06-11-2012   #16
x2.
Old 06-11-2012   #17
DavidPHumes
Yeah I don't know if I'll be able to torque them all down since they're in such hard to reach places. The only thing is that the tranny is kind of clocked (probably resting on the dowels) so I'll need to loosen the motor mounts to be able to rotate it slightly (it's barely off, but enough to where a bolt won't thread).
Old 06-11-2012   #18
I bet one or both of your dowels have fallen out or broken off. This problem almost only happens when those are missing. With that many miles on a modded car, it can definitely happen.
Old 06-11-2012   #19
IF it's solid motor mounts, i guess I'd maybe blue loctite them.
Old 06-12-2012   #20
DavidPHumes
Yeah, solid motor mounts. And I did blue loctite them
The transmission has never shifted smoother than it does now. Like butter. I'm guessing that some of the bolts have been missing for a while now. Luckily nothing else seems to have been effected.
To get the tranny clocked we undid the front engine/tranny mount and used a floor jack to get it where it needed to be.
Thanks for the help guys! Much appreciated.
You said they were loose... not totally gone
