Old 04-13-2005   #1
DSMkel
Send a message via AIM to DSMkel Send a message via MSN to DSMkel
New throttle body installed
Installed a Cyclone throttle body on my 95 TSi. Don't know if it's suppose to be a very big improvement or not??? It seems to have better throttle response over the stock one, is much easier to adjust, and fixed my idle problem. It did however require the cutting of my upper IC pipe and the use of a rubber coupler. Just thought I'd see wut anybody had to say about this or had any experience with adjusting it.
Type-Arrrrgh KILLA
"If it's never broke you're not driving it hard enough"
DSMkel is offline   Reply With Quote
Old 04-14-2005   #2
Re: New throttle body installed
It should have been an upgrade. 1g throttle bodies are bigger the 2g throttle bodies which allows more airflow.
Kel is gettin' with the program, I'm so proud.
Old 04-15-2005   #3
DSMPARTSGURU
Keeper of the lost toys!
Drives: 1977 pinto,1994 farm truck, 04 4-door mustang
Send a message via MSN to DSMPARTSGURU
hmmm, verry interesting that it cured an idle problem.... congrats though
chris
CHRIS
Wayzata Nissan
DSMPARTSGURU is offline   Reply With Quote
Old 04-15-2005   #4
chris
It could have been a plugged passage or bad ISC motor on the old throttle body causing his idle problem.
Old 04-15-2005   #5
DSMPARTSGURU
Thats what I was wondering.... Im glad I wasnt the only one thinking that way...
chris
CHRIS
Wayzata Nissan
Old 04-16-2005   #6
DSMkel
OK....idle problem is back. DERNIT!
Only sometimes though. Checked for boost/vaccum leak today and found none. Still have a temp sensor code.....could that be the problem? I have this little coolant leak which I was thinkin might allow enough air into the system to make the coolant boil out. That in turn might be screwin with the temp sensor which is sending a reading to the ECU and throwin the check engine light and also makin it idle according to the temp readings. Does this sound possible or am I completely off my rocker?
Type-Arrrrgh KILLA
Old 04-16-2005   #7
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Well the CTS will effect idle, so yes it is possible. But I would concentrate on getting the leak fixed, then get a new CTS.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
