Old 10-26-2005   #1
BOVADDICT
is in debt neck deep
Boost leak test and...
I was over at slowbubblecar's house and we boost leak tested my car. While testing my guage never climbed abover 0 just sat there. What could this mean?
galant vr-4 #46/1000 16g and supporting
240sx track
BOVADDICT is offline   Reply With Quote
Old 10-27-2005   #2
Re: Boost leak test and...
That means you have a huge leak that the compressor couldn't overcome. Or your guage is broke.
Old 10-27-2005   #3
Outlaw1
Resident Redneck
Outlaw1's Avatar
It means you'll probably get banned in five days.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 10-27-2005   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
His guage goes to 15psi when he drives it but doesn't do anything with the tester on it. I used the air compressor and couldn't even build 1 pound. It was putting out a lot of air. I couldn't hear a leak or anything after pulling the air chuck off. Could the turbo be his leak? I had this problem a long time ago with a car I parted out and I never figured it out on that either. I was wondering how he could build 15psi when the compressor couldn't even build one.
7/25/09
Old 10-27-2005   #5
Outlaw1
Resident Redneck
Outlaw1's Avatar
Something is wrong with the tester.
Old 10-27-2005   #6
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
It worked last time I used it
7/25/09
Old 10-27-2005   #7
x-pride
x-pride's Avatar
If this car still has a stock intercooler check the inlet and outlet of the intercooler. They get little holes in there and leak like hell.
Old 10-27-2005   #8
BOVADDICT
It has a stock intercooler. I'll check those today. Wouldn't that make a sound though?
Also super4x4duty, It was stated in RK's bitch thread that the technical forums should be taken seriously as most the others you can kid around with; so I would appreciate only serious answers when it refers to a problem with my car. Thanks
240sx track
Old 10-27-2005   #9
SlowTsi
Next time the tester is on, try removing a vac source that should be seeing pressure. That will tell you if the system is seeing any pressure. You could always bypass the turbo all together and run the test through an IC pipe, but thet might be difficult with the stock mesh hose.
Nathan
New owner of ecoli's PT67 :) and Brian's 2g magnus :)
another 500whp stock motor 2g?? maybe a windowed block?? we will see :D
SlowTsi is offline   Reply With Quote
Old 10-27-2005   #10
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
I am sure the intercooler isn't the reason. I would have heard a leak there and it most likely would have needed to build boost to get there.
7/25/09
Old 10-27-2005   #11
A lot of times the leak is so big that you don't hear anything. It was like that when Shane blew his end tank apart.
Old 10-28-2005   #12
BOVADDICT
Soooo. What do i need then? New ic?
240sx track
Old 10-29-2005   #13
No look for leaks! Take a bottle of sopy water and spray it all over anywhere there is an intersection while someone else pressurizes the system. Its a pretty simple process I dont know how anyone is supposed to guide you through it any easier unless they do it for you...
Old 10-29-2005   #14
BOVADDICT
I know what you are talking about. So on all my couplers test this? Sounds good thanks.
240sx track
Old 10-29-2005   #15
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
Lkjdafhsdfgkusfgkhsadgadfkjhdasfgk
Khadgar is offline   Reply With Quote
Old 10-30-2005   #16
quick2.4
OK the boost leak tester isnt to test your gauge just for listening to find your leak a boost leak tester dosent build pressure in the vacuum lines just the turbo piping thats why it dosent work
quick2.4 is offline   Reply With Quote
Old 10-30-2005   #17
Nash
Nash's Avatar
WTF are you talking about? It will build pressure in your system and it will show on your boost gauge. Unless the leak is really big then it might show nothing at all on the gauge.
Try putting the tester on your t-body elbow. Then you can narrow down the spots at where it could be leaking from.
Old 10-31-2005   #18
quick2.4
WTF are you talking about I thought it was a boost issue so why would he put it on his TB? your supposed to put it on the turbo inlet putting it on the TB isnt gona do a damn thing !!!
Old 10-31-2005   #19
Nash
Nash's Avatar
You are a fucking dumb ass. Could you have a leak at your t-body? Could you have a leak at your intake mainfold? Yes and yes. So putting it on the t-body will either eliminate those spots or show you have a leak at one of those spots. If there are no leaks there then it tells you that it's between the turbo and the t-body.
Old 10-30-2005   #20
Don't say something unless you know what the hell you are talking about. Are the vacuum lines connected to the intake manifold? Yes. Does it pressurize the intake manifold? Yes. Therefore it has to put pressure to the vacuum lines also.
