Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 06-22-2006   #261
4Las90
4Las90's Avatar
Drives: Evo 8 RS
Send a message via AIM to 4Las90 Send a message via MSN to 4Las90
Re: Finally getting stuff done on our cars
So how does July 9th sound for our little race?
Chris
Oops posted this as Bill, This is Chris aka v8klla
4Las90 is offline
Old 06-22-2006   #262
Nice runs for just coming off the trailer. That's a decent trap, especially for pump piss, I bet she'd scream with some real gas and boost.
Yeah, last time I set my rear Koni's to stiff, I fishtailed and almost hit the wall. The AWD's seem to like some rear weight transfer.
Goat Blower is offline
Old 06-22-2006   #263
Trailer? I drove there and back.
Yeah I nearly fucking bit it. The car hopped 3 times in the rear then I ground 2nd (woot!) and all was fine.
The 1.779 60' was nice, not to hard of a launch, but it spun flat and stayed straight, just what I want.
niterydr is offline
Old 06-22-2006   #264
Chris
I don't think I will have everything sorted out for race gas then.
I need a t-case and driveshaft, and a new trans now .
It might work, I'll be at rock, but probably on pump still, until I hit a 10.
niterydr is offline
Old 06-22-2006   #265
Nice times!! Good to see its back up and running!!! I want to see it in person.
A//// Guy is offline
Old 06-22-2006   #266
tim
tim's Avatar
Very nice traps Josh. Like you said, get the launch and shifting down and you will put out some impressive numbers on pump. I wanna see the race gas already.
Where was this btw?
tim is offline
Old 06-23-2006   #267
Runs were at BIR. We decided its race gas time next weekend.
niterydr is offline
Old 06-23-2006   #268
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Once it's tuned you gonna release dyno figures, that would be pimp. Glad to see it's running!
DoughtCom is offline
Old 06-23-2006   #269
Shrep
LSE Performance
Shrep's Avatar
I really think we could have gotten some better runs in, but with having to wait for the car to cool down, so that we could replace the coolant that it keeps deciding it doesn't want, we were only able to get in 3 runs.
Looks like we're gonna go next weekend and put some times down on race gas. Once we're satisfied there, we'll be back to work on pump.
Need to get that suspension sorted out, and that takes a lot of launches and number crunching to get right. I'm sure we'll have plenty of opportunity to get that handled next weekend in Iowa
Shrep is offline
Old 06-23-2006   #270
What headgaskets are in it? Sounds like one might be partially blown.
Shane@DBPerformance is offline
Old 06-23-2006   #271
Either that or the turbo's are hosed. Shane, have you heard of any failures with the ball bearing center cartigages?
We've done an exhaust test analysis of the coolant system, came up with nothing....I am going to pressurize the coolant stream tonight and re-do the test. I need to get to the bottom of this.
niterydr is offline
Old 06-23-2006   #272
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
I would go with the headgasket/s as well. Considering the boost you are running combined with pump gas. You never really posted details about the rebuid unless I missed them. How did you break in the new motor? Or did you? Did you do any other work other than internals?
TheBlizzard is offline
Old 06-23-2006   #273
I haven't heard of any problems with dual ball bearing Garrett turbos, they are usually more reliable than the normal journal bearing turbos. There have been a lot of problems with the HP version of Cometic headgaskets though. They supposedly discontinued them and only sell the MLS one now.
Old 06-23-2006   #274
Yeah, I am running the stocker MLS.
It could be a bad headgasket, but it isn't showing up in anything, I am doing another compression/leakdown test to check for it. God I do NOT want to pull the heads off.
Im going to do a comp test, break loose the studs, torque them to 100 and see if it fixes it.
If not, its time to tear shit down.
niterydr is offline
Old 06-23-2006   #275
I put a MLS on my car last year and it popped immediately for no apparent reason. I put the HP on and that seems to be fine. Looks like I will use a mitsu metal in the future if this one goes.
JET is offline
Old 08-05-2006   #276
Well got the nitrous figured out.
784.8AWHP, 660.1AWTQ 32psi +c-16 and 60 shot n20
1)My turbo's and intercoolers are pinned, only way to make more power is to add more nitrous, and I probably will.
2)I wanna go single next year, I am tired of the lag and heat, time to look at gt42's.
3)The car pulls 3061lbs of tractive effort in 3rd gear, that is nearly .8 g's of acceleration in 3rd gear!!
I am going to Rockfalls in a few hours, wish me luck.
niterydr is offline
Old 08-05-2006   #277
Speedfreak
Drives: four tires
Good luck. Go single and a nice huge intercooler.
Speedfreak is offline
Old 08-05-2006   #278
Shotgun!
Totenritt
Shotgun!'s Avatar
Singles are for pussies!
Shotgun! is offline
Old 08-05-2006   #279
I really doubt the turbo's are maxed, 392 whp for each 50 trim shouldn't be stressing it too much. The IC's though, I am sure they are totally maxed. Good luck at the track!
JET is offline
Old 08-05-2006   #280
Originally Posted by Shotgun!
Wastegates are for pussies!
Fixed.
FattyBoomBatty is offline
Closed Thread
