Old 07-14-2006   #21
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Re: Opinions of the following turbos...
I'm thinking about that T28 Killer also.
Tyler Aherns
-USN-
Old 07-14-2006   #22
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
just send in ur blown turbo its worth a $300 core charge so hold on to it
here a link on the specs
http://linux.forcedperformance.net/m...Code=DSM-Turbo
Old 07-14-2006   #23
98gstaherns
Are you sure that is a Killer?
Tyler Aherns
-USN-
Old 07-15-2006   #24
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I thought so I dont know...
Old 07-15-2006   #25
98gstaherns
This is a Killer http://www.turbochargers.com/Turbos/.../T28Killer.htm
Tyler Aherns
-USN-
Old 07-15-2006   #26
Thor06
11 Seconds to Freedom
Thor06's Avatar
I would personally just get an Evo III 16g. I think they are pretty comparable power wise but last I checked the T28 killer was way more than the Evo III.
Old 07-15-2006   #27
Check your sources.
Old 07-15-2006   #28
95tsi
95tsi's Avatar
Drives: a pos
t28
When I called FP about my T28 they told me to run it til it spikes to around 28psi then falls back down to 21 or so. Not a bad turbo and looks bone stock. Just lacks the top end power of anything else. Great spool up, but from what I've read the Evo 16g will make more power. I'd recommend it for autox or drag. Seems to work well for both. Just probably wont hit an 11 on it without significant mods.
Old 07-15-2006   #29
If you want easy installation and a stock look go with the FP Big T28. Anything else will require more parts for the change over.
Old 07-17-2006   #30
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
are you on a tight budget? if so I highly recommend just a garrett t3/t04e... I got mine for $500 shipped brand new.
Old 07-17-2006   #31
How about FP Green or Red?
Old 07-17-2006   #32
Definitely both proven very well. Just out of curious for the old codgers around here, has FP ever had a truly shitty turbo?
Old 07-17-2006   #33
I've never seen one. There new stuff is much better than the old, but for the times, the old stuff was pretty damm good as well.
Old 07-17-2006   #34
Thor06
Thor06's Avatar
Correct me if I am wrong, but arent the red and green turbos nothing more than garret 50 trim and 60-1 (cant remember which is which) center sections with FP's mitsu bolt up turbine housing?
Old 07-17-2006   #35
They have Mitsu exhaust wheels also, which were quite a bit better than the normal Garrett exhaust wheels. The GT Garrett exhaust wheels nowdays are good though also.
