Old 07-27-2006   #1
basic engine assembly questions
Is plastigage still "the" way to get a fairly accurate oil clearance? Or can i just borrow a digital caliper and do some arithmatic?
Rods: when torquing the caps, do most of you go by the torque rating, bolt stretch, or both?
Front case: Brand new oem; should i take the oil pump cover off and clearance the gears or are they usually within spec? I've also heard of people deburring the gear edges, whats the reasoning behind that?
i was also wondering if anyone had a decent set of machinist guages so i can check my block now that i finally got it back. i just want to make sure the bores aren't tapered or anything else drastic.
Old 07-27-2006   #2
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: basic engine assembly questions
plastigage works just fine. I measure the crank and rods with a digital caliper tool though. It works better, for more accurate info, i think. I still tighten everything down with plastigage though, just to double-check for tolerances.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 07-27-2006   #3
Swifty1638
Swifty1638's Avatar
as or the rods, i toque them all down to like half of the way, then go back, and go the rest of the way, similar to the way you torque a head down. I go by the specs, not by what the part can take.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 07-27-2006   #4
I've never heard of doing anything with the oil pump. I have a brand new case and gears in my hands and they don't look like I should have to do anything with them. It's up to you obviously. I'm guessing they beburr the gear edges do they don't scratch the casing which would be putting aluminum filings into the oil.
Old 07-27-2006   #5
The digital caliper won't tell you crap, use plastigage in 3 different spots, then average the clearance. You need a bore guage if you want to do it by measurements, but most people won't have one.
Old 07-27-2006   #6
Bore gauge/mic's and rod bolt stretch method.
But we have all those tools here.
Old 07-27-2006   #7
can i bring my block over to your shop swanny?
i'll even buy one of those turned down balance shafts!
Old 07-30-2006   #8
GVR-4579
+1 on not using a mic, mine reads a bit different between ID and OD and it confused the hell outta me one day
Old 07-31-2006   #9
Buy a good mic or learn how to read it.
Old 08-01-2006   #10
GVR-4579
it is good, and its digital but it read off like .002 between ID and OD so it was throwing off the oil clearances
Old 08-01-2006   #11
A mic can't read ID, you must be talking about a caliper. The ID should be read by a bore guage.
Old 08-02-2006   #12
GVR-4579
Opps yea i always get those messed up, yea thats what i did, got out the old starretts and went at it and found that everything was ok. wow feel kinda dumb about messing those up again but i get them confused all the time. LOL
Old 08-02-2006   #13
thanks josh and swanny for checking my cyl diameters for me. i guess the ramsey Carquest does pretty good machine work
