Old 08-21-2006   #1
bmikkalson
Where to get a crank kit for a 2g
Hi, long time lurker first time poster.
Any event I have a stock 2g DSM that one 0f the rod bearings spun on the crank. Any ideas on where to get a crank kit? or would it it advisable to just put a new short block in? Thanks
bmikkalson is offline   Reply With Quote
Old 08-21-2006   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Where to get a crank kit for a 2g
It would be better to put a 6 bolt motor in it. (90-92.5 motor) If you fix the stock 2g motor, you'll never know if it is going to do the same thing down the road.
Originally Posted by shoutbox
Old 08-21-2006   #3
Gravy
Who's this guy?
I bleive it's almost a guarantee it will "Walk" again. It's just a matter of when, and how long. Do the extra work needed to swap in a 1g turbo. Look for a 6 bolt, and don't bother installing a 7 bolt.
You can find instructions on VFaq.com.
Old 08-21-2006   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
After re-reading your post, I'm guessing this car is a 2g turbo? If it isnt, forget what I said.
Old 08-21-2006   #5
bmikkalson
This car is just my daily driver, And I may even sell it after I get it fixed.
Old 08-21-2006   #6
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Crankshaft supply will have what your looking for.
Old 08-21-2006   #7
A rod bearing failure is not crankwalk boyz.
If you're endplay is fine, just have the crank turned and put in the .010 under bearings to go with it.
Old 08-21-2006   #8
Shotgun!
Totenritt
Shotgun!'s Avatar
Goat Blower FTW!
Old 08-21-2006   #9
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Your still messing with the thrust bearing. Just like playin with the devil.
I never said it was crankwalk. Just greater chances of getting if you screw with it.
Old 08-21-2006   #10
bmikkalson
Thanks guys, I will give Crank shaft supply a call in the AM
Old 08-22-2006   #11
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
No problem, glad to help.
Old 08-22-2006   #12
Actually, if you set the crank properly, it shouldn't be a problem if it wasn't already. 9 times out of 10 that's what causes CW in rebuilt motors, including 1Gs.
Old 09-08-2006   #13
mike55112
mike55112's Avatar
Drives: 04 evo
I have a extra 2g crank. I am in the process of doing a 6bolt swap right now in my 95gsx
