Go Back   MitsuStyle > The Homefront! > Everything Racing
Old 10-21-2006   #21
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: Oct. 14th & 21st.
Just tack them on Jet and then grind them when you remove them. Shit this has to be the third of four time you have had to remove the tranny because of this. Wonder why? The twin disk rattles a lot? Motor mounts? Its weird.
Old 10-22-2006   #22
Have you tried getting new flywheel bolts? Maybe the stockers are stretched and not holding anymore similar to when you reuse manifold-to-turbo bolts.
Old 10-22-2006   #23
What about drilling a small hole through the head of each bolt and putting a safety wire through them?
Old 10-22-2006   #24
Tack weld and safety wire have both been considered. I will probably do one of the two next time if this doesn't hold. Probably the tack weld.
