Old 11-06-2006   #21
Re: Dart Block
Re-opened per request and cleaned up.
Old 11-06-2006   #22
Re: Dart Block
That could work for a drag only car, but you would need something cast for the street to be able to cool the cylinders.
How so? When a part is reverse engineered, everything is taken in account (coolant passages, etc.). Here is the name of the company I was talking about:
http://www.adcinc1.com/
A good friend of mine at Purdue sent in the heads off of his family's pulling tractor and had CAD models produced to which he has based his CNC porting off of. He also did some other goodies before finalizing the porting specifications but I won't mention that for the time being.
Old 11-06-2006   #23
Re: Dart Block
Why? You'd still have to use sleeves since you obviously can't have aluminum cylinder walls. Water passages are water passages, material doesn't matter much. Unless you're talking about a solid block, which would be drag only. Or street/drag is your last name is Hess.
Old 11-06-2006   #24
Re: Dart Block
I was referring to the statement about a big ol' chunk of 355-T6 aluminum. That would be a solid block. You have to cast a street block to form the coolant passages. Solid block would be race only.
Old 11-06-2006   #25
Re: Dart Block
Why couldn't the passages be machined?
Old 11-06-2006   #26
Re: Dart Block
How would you machine inside the block so coolant could encapsulate the cylinders?
Old 11-06-2006   #27
Re: Dart Block
CNC machining since you need sleeves no matter what in an aluminum block.
Old 11-06-2006   #28
Re: Dart Block
Yeah, you could easily machine that out. Might have to put a few plugs in the block for the outside end of some passages, but it could be done. Definitely not worth the effort though.
Old 11-06-2006   #29
Re: Dart Block
Okee, dokee.
