Old 12-19-2006   #1
stcloudgsx
stcloudgsx's Avatar
Send a message via AIM to stcloudgsx Send a message via MSN to stcloudgsx
New Computer Question
I just finished building myself a new computer and I'm having an overheating issue. When I got everything up and running and all updated, the temps for both cores were at 41*C. Then last night, I was playing the new flight simulator when I got a great blue screen. After this, my computer has been running at 57-60*C at idle. Does anyone have any idea what could be causing this? Thanks
stcloudgsx is offline   Reply With Quote
Old 12-19-2006   #2
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
Re: New Computer Question
Blue Sceen of Death
Post up your setup and what thermal compound did you use?
Originally Posted by ecoli
Some cars are so slow that even the cops can't tell they are racing.
http://www.myspace.com/kounpheng
YiNYaNg is offline   Reply With Quote
Old 12-19-2006   #3
stcloudgsx
stcloudgsx's Avatar
asus p5n32 sli se deluxe, Intel E6600 core duo, nvidia 7950gx2, aspirex case. 2gb corsair pc6400, 147gb 10k raptor hard drive. I just used the thermal paste that was on the processor heat sink.
Old 12-19-2006   #4
YiNYaNg
YiNYaNg's Avatar
Go get this stuff.
http://www.arcticsilver.com/as5.htm
Old 12-19-2006   #5
What HSF did you use? This is something not to be skimped on!
Your video card may have also overheated, causing the BSOD....
Old 12-19-2006   #6
stcloudgsx
stcloudgsx's Avatar
Well I already ordered a thermaltake Big Typhoon heat sink and some arctic silver5. What exactly does HSF mean? I'm still really new to building computers as this is my first. thanks for the help
Old 12-19-2006   #7
HeatSinkFan Unit
make sure that bad boy is seated correctly, and that there is not too much thermal paste on there.
Old 12-19-2006   #8
YiNYaNg
YiNYaNg's Avatar
My P5N32-SLI and P4 Cedarmill @ 3.6ghz idles at 16° C
That 8-Phase Power Design should be helping with the temps but that factory thermal compound I'm not to sure about.
Old 12-19-2006   #9
stcloudgsx
stcloudgsx's Avatar
Alright thanks for all the replies, but does anyone have any clue why it would continue to run hot even after the BSOD? Before it was idling at ~41*C and now the cores idle at 58*C. Thats quite a hop.
Old 12-19-2006   #10
YiNYaNg
YiNYaNg's Avatar
Any overclocking?
Old 12-19-2006   #11
stcloudgsx
stcloudgsx's Avatar
Nope, running the stock 2.4ghz.
Old 12-19-2006   #12
YiNYaNg
YiNYaNg's Avatar
Do this and report back.
Old 12-19-2006   #13
YiNYaNg
YiNYaNg's Avatar
Forgot, that's only with factory heat sink with Arctic Silver 5
Have you looked into watercooling?
Old 12-19-2006   #14
dumb_ricer
Hates Everything
Drives: Neon
If its your first build odds are you used wayyy too much thermal compound. You barely need to coat it, and only coat one surface (HSF surface).
Make sure the HSF fan is turning too, and that there is good airflow getting to that area of the case.
420A > LS1 > All Else
I > All else
Old 12-19-2006   #15
stcloudgsx
stcloudgsx's Avatar
Well the thing is, the HSF came with the thermal compound applied to it in 3 small strips. All that was needed of me as per the instructions was to install the HSF to the CPU. I just don't know what happened.. After the BSOD the temps are now 15*C higher at idle than they were before it.
Old 12-19-2006   #16
Something is obviously messed up between the processor and the heat sink. If they are not perfectly in contact by any amount it will overheat. Take it apart and try again.
Old 12-19-2006   #17
Check for a change in your BIOS settings. Make sure the cooling fans are working, don't just assume they are.
