Old 02-22-2007   #1
91autoeclipse
alternator squeal.?
is this a sign that my alternator is going out.. ?
91 GSX..
squeals.. a lot when cold.. and even now that it is warmer it does squeal at lower RPM..
any answer would be great..
tsua
91autoeclipse is offline   Reply With Quote
Old 02-22-2007   #2
Re: alternator squeal.?
Tighten the belt.
Old 02-22-2007   #3
johnson
johnson's Avatar
Drives: 90mitsu
^^^^ ditto!!!!
Old 02-22-2007   #4
Maybe also check your Alternator fluid in case it's low.
Old 02-22-2007   #5
Assuming the car is a 1G, the alternator fluid passes through the flamidation valve between the reservoir and the alternator. If there is something causing a flow restriction in the flamidation valve, the alternator could be getting starved of fluid.
Old 02-22-2007   #6
johnson
johnson's Avatar
Drives: 90mitsu
fluid????
Old 02-22-2007   #7
sleepy2lazy
sleepy2lazy's Avatar
Alternator fluid? What is that........
Usually I just spray some wd-40 on it or else tighten it.
Old 02-22-2007   #8
Yup, just like how you need to check the water in your battery. You need to check the alternator too.
Old 02-22-2007   #9
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Originally Posted by johnson View Post
fluid????
You really are behind on the technology, aren't you? Get with the program man!
Old 02-23-2007   #10
johnson
johnson's Avatar
Drives: 90mitsu
i have a 1g alternator in front of me and i dont see any fluid.....
Old 02-23-2007   #11
I have 2 1g, and a colt one, all in front of me. They are all at the perfect level.
Old 02-23-2007   #12
yeah, i had a problem once, i drop PS fluid all over my alt. and it got in it. Then i had to drain it and refill it.
Old 02-23-2007   #13
johnson
johnson's Avatar
Drives: 90mitsu
only if i knew what i was lookin for??? thats why i have the pros rebuild my alt...
Old 02-23-2007   #14
twack
It was a auto get over it
twack's Avatar
Probubly a good thing
Old 02-23-2007   #15
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Your alternator squeals? It means it wants out... You are hurting it. Your ECU probably has a virus and I bet your cams arent camming right.
Better check the Variable Transister Accumulator Kintetisizer while you are in the area.
On a side note, if you cut the belt, it wont squeal anymore.
Originally Posted by shoutbox
Old 02-23-2007   #16
Ya but cutting the belt is just a band-aid. You need to fix the root cause, which is probably your fluid level.
Old 02-23-2007   #17
b00stcreep21
I hate everyone
b00stcreep21's Avatar
HAHA, you've gotta be kidding me....
Old 02-23-2007   #18
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
Funny, Funny, Funny!!! Had me saying WTF, Ahhh yes the fluid how could I be so Stupid..
Old 02-23-2007   #19
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
those damn alternators are always leaking!!
i believe i just became dumber...
p.s. dont forget to check the flux capacitor... always givin me troubles..
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 02-23-2007   #20
bluntedelvis
Click,Click,BOOM!!!
I can never find enough power to supply the 1.21 gigawatt for my capacitor.
