Old 09-14-2007   #21
Re: Turning my quest into a dsm.
I've got realtime 3d visuals of all 8 parameters of my engine. Actually I just made that up.
I do have a question, what is the firing order of the coil pack? does it just go 1-2-3-4? or like 1 and 3 are together? this would be a 1G thing, not sure if it's different for 2g's, i don't care.
Old 09-14-2007   #22
1-4 and 2-3 are together.
Old 09-15-2007   #23
yay, I plugged it in and got signals for everything. Holy crap is the aem complicated. I have some reading to do. And my tps is wired backward, I should have expected that, lol.
Old 09-15-2007   #24
Here's some more pics as of friday. This is the new-ish setup for wiring. I bought some new split loom tubing for all this, so it'll be cleaned up more, but I re-routed the ignition wires and stuff to go through the secret passage above the wheel well.
This is where the stock engine harness came through. Now it's the knock and O2 sensors and the coil pack and transistor plugs.
And here's the location of the stuff.
And now I have to connect the plug wires, switch the + and - on the tps, make sure I have the right settings for starting it up and it should go. yay.
Old 09-16-2007   #25
Shotgun!
Totenritt
Shotgun!'s Avatar
Good luck buddy!
You went farther than I thought you would!
Old 09-21-2007   #26
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
So hows this coming?
Old 09-23-2007   #27
TenSecondG54B
Cool! I'm glad somebody else finally got the idea working!
You better post videos when your finished...
Tuck them wires!
TenSecondG54B is offline   Reply With Quote
Old 09-23-2007   #28
This has been put off for a couple weeks because of various delays. But I think this friday I'll be working on it, maybe try to start it. But I think I need longer plug wires. And of course, it depends on if fuel doesn't leak etc. If it starts, then I will not worry about tuning or driving it untill I get the boost tubes worked out, I/C mounted and all the little stuff.
Old 09-27-2007   #29
TenSecondG54B
I posted your pictures for you over at SQC.
Old 09-27-2007   #30
Thanks! I'll just keep adding more here, and if you want, feel free to put 'em up there. I will be taking more tomorrow (friday).
Old 09-28-2007   #31
Happy birthday to me. Apexi GT core. It's damn huge. I hugisized it for 79 cents.
I have to cut the bumper supports quite a bit, and I can't really do that in this warehouse I'm in (I think) so that install might have to wait. then I'm getting some Al. pipes, I'll need a bov, the new manifold (yet to buy) and the exhaust welded up and it should be all done mechanically by then.
Oh yeah, do I need a special timing light to check timing since it's wastespark? Or will it just read twice what it really is?
Old 11-17-2007   #32
Here are the latest pics, I cut away a good section of the bumper to make way for the ginormous intercooler pictured above. I think it'll be ok for the time being, I plan on having it re-inforced later, once the car is running. Next I have to cut the frame rails to match the removed section of the bumper supports. Who needs collision protection anyway, right?
This is my AEM file I'm working with right now, the only thing I changed since I've tried starting it last is the rev limiter "load psi fuel cut" setting, which was -14.69PSIg. I thought maybe that was the reason it would crank and stumble, but never start. I'll try it later, if anyone else wants to take a look at it and suggest improvements, please do so, I know Ryan is going to take a crack at it, he's been really helpful with this slow-going process. I am quite the n00b with the AEM, but slowly gaining knowledge. THANKS again!
(I had to put it in a zipped folder since you can't attach .cal files. )
Old 11-20-2007   #33
It's Alive!
Thanks for the hints, and I finally figured out how and where to add fuel with the help of some good friends. No names but his initials are Josh Swanberg (sp?). Thanks man! Ryan, you too. Now I can focus on the details and get 'er ready for tuning.
Oh and unfortunately it still sounds like a conquest hehe. (I spose that is actually a good thing).
Old 11-20-2007   #34
Kougar
Drives: 06 RSX
Grats mang.
Old 11-21-2007   #35
Awesome!
Old 11-21-2007   #36
It's Alive!
Glad my "Hints" helped ya .
Old 11-21-2007   #37
Good to see that thing is still alive, its been too long, oh how i miss thee.
our frum anything action should be a lot quicker these days, don't ya think?
Old 11-21-2007   #38
Kougar
Drives: 06 RSX
Pics don't show - still have that girl turbo on there, Andrew? Jesus cries when a 12A and MPI are in the same engine bay!
Old 11-21-2007   #39
Black97civic
35mpg
If the 12a is still in there, it is only a temporary matter. I have seen the replacement, and it moves a little bit more air...
Old 11-21-2007   #40
That isn't saying much!
