Old 10-11-2007   #61
Re: "v"
That is the same core I have here waiting to go on my car
Old 10-11-2007   #62
Re: "v"
I'll post how I like it once it's done. This seems to be the "go to" core that people are recommending these days.
Old 10-17-2007   #63
Re: "v"
Here are some pics and update.
I don't think anybody would want to fit a bigger core to the front of a 2g. It takes up just about all of the available space, unless you really want to hack up the car/bumper. Although the LICP is 2.5 inches, we jumped it up to 3.0 at the inlet to the core, just in case I ever needed to go bigger it would be as simple as replacing the LICP. The pipes were trimmed to the shape of the tank openings so there would not be any pipe protruding into the tanks. We are running 3.0 inch up to the TB elbow. Still haven't decided which TB I want to go with yet, I'm working on that, but it will be done later. The tanks are made from .090 aluminum. We pressure tested it @ 42psi to make sure the welds would hold and check for leaks. We have engineering templates made for the tank panels that I'll try to scan and post later if anybody wants them. We cut the lower part off the bumper support brackets to make room for the intercooler pipes as seen in the pics. Everything will fit under the bumper and retain the driving/fog lamps. I'll post more pics as we go.
Name:	Intercooler 001sm.JPG
ID:	6434   Click image for larger version
Name:	Intercooler 002sm.JPG
ID:	6435   Click image for larger version
Name:	Intercooler 003sm.JPG
Name:	Intercooler 006sm.JPG
ID:	6440   Click image for larger version
Name:	Intercooler 007sm.JPG
ID:	6441   Click image for larger version
Name:	Intercooler 008sm.JPG
Name:	Intercooler 009sm.JPG
Old 10-17-2007   #64
Re: "v"
That is a big core man, and I LOVE the piping! I like how you cut off the bottom half of the bumper support, great idea!
Old 10-17-2007   #65
Re: "v"
Yeah, the person doing the fab work for me said "you want to put this where!?!?!?!?" when I handed him the core.
I'm lucky that I found a great guy to do my fab work for me, top notch work and perfectionist, same person who did my exhaust work for $200. Wants to charge me only $300 for fabbing up the intercooler and all the piping!! I'm going to pay him more than that though. The place we're doing the work in is actually his workshop at his house. He's got Cincinnati and Bridgeport units in there, metal lathes, sheet metal benders, multiple Miller welders, drive on rack, etc, etc. Top notch guy.
Old 10-17-2007   #66
Re: "v"
That looks really nice!
Old 10-22-2007   #67
Robert Venable
Robert Venable's Avatar
Re: "v"
MIKE,
Who is doing the fab work for you (if you are allowed to say)?
1990 Mighty Max
Robert Venable is offline   Reply With Quote
Old 10-22-2007   #68
Re: "v"
Originally Posted by Robert Venable View Post
MIKE,
David Howell, welder/machinist for Exxon/Mobil.
Old 10-22-2007   #69
Re: "v"
Well it's finished. Here are the latest pics. We had to trim back the bumper to clear the inlet/outlet pipes and make room for the thicker intercooler. If you look in the side vent openings you can see where we trimmed the top of the openings to clear the pipes. Came out very well. Now I just need to decide on a throttle body.
Name:	Intercooler 011sm.JPG
ID:	6451   Click image for larger version
Name:	Intercooler 012sm.JPG
ID:	6452   Click image for larger version
Name:	Intercooler 013sm.JPG
Name:	Intercooler 014sm.JPG
ID:	6464   Click image for larger version
Name:	Intercooler 022sm.JPG
ID:	6465   Click image for larger version
Name:	Intercooler 023sm.JPG
Name:	Intercooler 019sm.JPG
ID:	6468   Click image for larger version
Name:	Intercooler 020sm.JPG
ID:	6469   Click image for larger version
Name:	Intercooler 018sm.JPG
Old 10-22-2007   #70
Re: "v"
A couple of underhood shots, not the greatest pics, but you get the idea.
Name:	Intercooler 024sm.JPG
ID:	6471   Click image for larger version
Name:	Intercooler 025sm.JPG
Old 10-22-2007   #71
Re: "v"
Wow, looks like great install work. Nice job to your fabber!
Time to cut out the black portion of your bumper's center opening?
Old 10-22-2007   #72
Re: "v"
The way we installed the intercooler was to butt it up very close to the underside of the bumper support with plenty of clearance in front of it. This makes a high pressure area while the car is moving which will push air through the upper part of the intercooler that is not visable from the front.
ID:	6473   Click image for larger version
Name:	Intercooler 015sm.JPG
ID:	6474   Click image for larger version
Old 10-22-2007   #73
BuildADSM
Re: "v"
Cool! How did you decide to put the bumper support directly on the IC?
I assume that you didn't want to go wider because you wanted to keep the stock fogs instead of going aftermarket.... or is there another reason?
Any cooling issues?
Looks great man!
Old 10-22-2007   #74
Re: "v"
Any cooling issues?
Looks great man!
Well it's not directly on it, there's about a 1/4 inch gap at the top. Really came down to making sure the core didn't hang too low on the car. The tight fit at the top was just a benefit. Yeah, I wanted to keep the fog lights (it is a street car). I like keeping the outside appearance as stock looking as possible. Other than the FMIC and the exhaust it looks like any other 2g with nice wheels and tint. This core is supposed to work really well and I didn't want the end tanks to be too shallow/tight to the core. I wanted the air flow to make a smoother transition from the pipes to the core. Drove it home yesterday, no signs of overheating at this time.
Old 10-22-2007   #75
Re: "v"
Looks very nice!
Old 10-22-2007   #76
Re: "v"
Here's a better under the hood pic.
Name:	Intercooler 026sm.JPG
Old 10-22-2007   #77
BuildADSM
Re: "v"
Cool, sounds alot like my brother his car is all stock on the outside other then the IC, hood, and painted center tail light piece.
He went with a different IC that is longer and used driving lights mounted in the fog light holes.
http://people.clemson.edu/~jamesj/pi...0106_18251.htm
Old 10-29-2007   #79
Re: "v"
Very nice! I like the end tank design, definitely better than a lot of the mass-produced models out there.
Old 12-17-2007   #80
Robert Venable
Re: "v"
Updates????
1990 Mighty Max
