Old 11-05-2007   #41
Re: Which cams?
Originally Posted by slowboy View Post
It's too bad you need to upgrade to dual valve springs to use the FP3 cams, because that's what I'd want to use, but that extra $350 is a little spendy on top of buying the cams too.
Only the "x" grinds of the fp3 cam.
Old 11-06-2007   #42
Re: Which cams?
FP3 and FP3x cams require dual springs.
Old 11-06-2007   #43
blageo23
AWD4G64
blageo23's Avatar
Re: Which cams?
The FP2X, FP3, FP3X, and FP4 require the dual springs. But Think Im set of the FP3x cams and the FP dual valve springs.
Old 11-06-2007   #44
Re: Which cams?
oops, there i go being wrong again.
Old 11-09-2007   #45
Re: Which cams?
FINALLY!!!! After my cams were shipped out on october 17th, they finally are in Los Angeles!!!!! I just checked the status randomly on the website and its finally showing that they are in california. I thought they were lost forever. So they should be here today!
Old 11-09-2007   #46
Re: Which cams?
This thread is about tech, not LOOK AT ME posts ya whore!
Old 11-09-2007   #47
Re: Which cams?
your a dipshit now stfu.
So they got here.
Here are the specs of them:
Intake:
Gross Valve Lift: .411
Cam Lobe Lift: .239
Adv. Dur @.050 3 btd 29 abd
102.0 centerline
Duration @ .050 212
Exhaust:
Gross Valve Lift: .395
Cam Lobe Lift: .232
Adv. Dur @.050 46 bbd 14- atd
120.0 centerline
Duration @ .050 212
Someone wanna explain what all these values mean?
Old 11-10-2007   #48
Re: Which cams?
Gross lift is after you take the rockers into effect, cam lift is just the cam. Duration is how long the cam stays open. A very important factor that is rarely included is the ramp angle, that is the biggest factor in if you need stiffer valve springs.
Old 11-10-2007   #49
Re: Which cams?
Overall do those cams look like a decent upgrade from stock?
Old 11-10-2007   #50
Re: Which cams?
your a dipshit
You're. Thanks for playing.
Old 11-10-2007   #51
Re: Which cams?
The spec's say they are. Pretty much anything is better than stock.
Old 11-10-2007   #52
Re: Which cams?
So they got here.
Intake:
Cam Lobe Lift: .239
102.0 centerline
Duration @ .050 212
Exhaust:
Cam Lobe Lift: .232
120.0 centerline
Duration @ .050 212
So you bought cam's without knowing if they would be a "good" upgrade, or knowing about specs?
I have Ocean Front property in North Dakota for sale, pm me if you are interested.
Old 11-10-2007   #53
Re: Which cams?
I knew they were an upgrade but i just wasnt sure How good of an upgrade it was. I actually feel a lot more power up top.
Old 11-11-2007   #54
x-pride
x-pride's Avatar
Re: Which cams?
I have even a better Ocean Front Porperty in West Dakota! Good one Josh!!!
