Old 11-12-2007   #1
95talonracer
95talonracer's Avatar
Blowing out antifreeze
I have a built 2.0 and am running around 28 psi on e-85. When I hit boost I have noticed that it blows the antifreeze out the overflow. It is not overheating and there is no antifreeze in the oil. It is not burning any antifreeze either. I have arp headstuds and a Commetic metal head gasket all torqued down. Is the coolant cap pressure not high enough or what would be causing this?
Amsoil Dealer
Old 11-12-2007   #2
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Blowing out antifreeze
I would try a different cap and see if that makes a difference.
Old 11-12-2007   #3
Sounds like a blown headgasket possible. You are pressurizing the coolant system, most likely.
Old 11-12-2007   #4
Sounds like a blown HG. Was the block decked?
Old 11-12-2007   #5
95talonracer
No it is not. When I brought it in to dyno it early in the year they overheated it on the dyno and it was boiling antifreeze out. Could that reck the gasket and nothing else. This probleb has just started in the last 2 months. Runs perfect besides under full boost. Can I just get (MLS commetic or mitsu, which is better) gasket and put it on with no problems hoping that it was the gasket or is the head warped maybe? I really dont want to have to take the motor out again. What would you do?
Amsoil Dealer
Old 11-12-2007   #6
If it overheated it could have definitely warped the head. I had that happen to a car, then shortly after that a rod bearing went. Mine was more drastic than yours though. I would put a stock headgasket on and see what happens, they have more give in them. You are supposed to have a decked block when going to a MLS gasket.
Old 11-12-2007   #7
Yea, sounds like a somewhat blown headgasket. You can have a barely blown headgasket that only shows itself under boost. I usually doesn't hurt power either, but can cause overheating and eventually fail in a much worse way.
Overheating can warped a head and blow a headgasket, but who knows which came first. Often overheating is caused by a blown headgasket. You might be able to just get the head decked and put in a stock headgasket. It is obviously easier to get the head decked than to pull the block and disassemble it to get it decked.
I had a problem with the 6-bolt motor that I got for my wife's 1G a few years ago. It could run or idle forever and never overheat, but as soon as you tried to do a boosted pull, it will push coolant like crazy. After trying everything and headgaskets, we had to pull the motor and get it decked. It hasn't had any problems with pushing any coolant since then.
Old 11-12-2007   #8
Lets pull the head! And then make your engine bay pretty at the same time, especially that sexy red intake manifold.
Old 11-12-2007   #9
blageo23
AWD4G64
blageo23's Avatar
Would that show up in a leakdown test?
Old 11-12-2007   #10
b00stcreep21
I hate everyone
b00stcreep21's Avatar
bad headgasket, warped block/head, or bad t-stat housing cap. the end
Old 11-12-2007   #11
blackawdtsi
Drives: 2G DSM
When was the last time you retorqued them?
Old 11-12-2007   #12
Thor06
11 Seconds to Freedom
Thor06's Avatar
I dont think so, I think thats mainly tests for bad rings or bad valve seats, someone correct me if I am wrong.
Definately sounds like a tweaked headgasket to me.
Old 11-12-2007   #13
blageo23
AWD4G64
blageo23's Avatar
Pop off the RAD cap and if there is bubbles during a leakdown test its caused by a bad HG. I know that a blown one would but would a blown headgasket like they are saying show it?
Old 11-13-2007   #14
A small leak, like this seems to be, does not always show up. Yank the head and check it out. Might as well replace the radiator cap first though, for the heck of it.
Old 11-13-2007   #15
If it only leaks under boost the ~100psi you put in there on a leakdown test will not show a blown head gasket.
Old 11-13-2007   #16
jhaan_dude
jhaan_dude's Avatar
Drives: a car
johns right, considering the stock motor makes 135 psi in the cylinders, that wouldnt work, but back to the part about the studs, did you ever retorque them????? and have you tried putting a little oil in the cylinder and done a compression check to see if you even get 135 psi per cylinder?!?
Old 11-13-2007   #17
blackawdtsi
Drives: 2G DSM
I thought stock was 160 and the service limit is 130??
Old 11-13-2007   #18
blageo23
AWD4G64
blageo23's Avatar
That oil thing doesnt work. Because our pistons have a dish in them all you are doing is filling up the piston with oil giving you a little bit higher number.
Old 11-13-2007   #19
Under boosted combustion you might have 1000-2000psi of pressure in the cylinder, so often a simple compression test or leakdown test doesn't show anything for a headgasket that only leaks under boost.
