Old 01-08-2008   #21
Re: My Winter Upgrades
Ahh man if I knew you wanted some of those I would have sold you my old h4 conversions from my popup 1g. Looks good though!
Old 01-09-2008   #22
Did you have to grind away or modify anything to get yours to fit?
Old 01-09-2008   #23
polishmafia
Smells like cat poop
polishmafia's Avatar
Ricer Polish Pete at Maple Grove Goodyear hooked me up with some H4 pigtails for dirt cheap, that I soldered in just now. Worked like a charm, thanks Pete!
my pleasure!
this looks like an awesome build you have going.
Old 01-09-2008   #24
No I just popped mine in. Had to seal the H4 bulbs I put in though.. with silicone since the rubber cap wasnt so great. I had hid looking 100 watt bulbs in there. haha
The beam pattern was good on low beams but highs sucked... I did have to modify the wiring but those adapters you got work better.
Old 01-09-2008   #25
Ricer.
Old 01-09-2008   #26
I had some H4 bulbs in a vw scirocco, but they weren't re-wired or something needed to be done, but they were really dim. As long as you get 'em bright, they should be pretty sweet.
Old 01-09-2008   #27
ali has a set of the h4 headlight I put in her 90 they fit with out any grinding
Old 01-09-2008   #28
My galant uses these kinds of bulbs from the factory. Peter, got any pics of what yours look like? I didn't really get an adapter though. I just cut off the stock connectors, and Pete got me some H4 pigtails, and I just soldered them on, heat shrank em, made it look purdy.
Old 01-09-2008   #29
Ricer.
Sailor.
Old 01-09-2008   #30
I got some pics at home yea. Ill see if I can post them. Ahh ok, yea I just used some big electrical connectors and hooked everything up that way.. ha
Old 01-10-2008   #31
N/T throttle body is going in here shortly!
Old 01-10-2008   #32
Sweet! How big are those? I'm putting a 65mm ported stocker on my evo here soon....
Old 01-10-2008   #33
How much bigger than stock are those?
Old 01-10-2008   #34
They are the same size. I got it for $30 of ebay. The thing I like about them is that instead of having a TB elbow attach to it, you just clamp a coupler right to it.
Also took the old FIAV/ISC blockoff plate off of my old TB and put it on this one. QPR ni66az
ID:	6789   Click image for larger version
Old 01-10-2008   #35
oh i see, that good, cause then i would have a boost leak, but then you have to buy new hardware too right, cause u will need shorter bolts.
Old 01-10-2008   #36
Yes I will. I plan on changing a lot of my hardware this winter though. ACE right up the road has a pretty good bolt selection I think. I'm going to probably switch to some black hardware were I can. Possible socket head bolts if possible.
Old 01-11-2008   #37
Well headlight housings have been ground, and headlights are in and functioning. Right now they have some blue light bulbs in them, which they came with. I'll see how they work, and if they are crap I'll just put in some normal ones.
ID:	6792   Click image for larger version
ID:	6793   Click image for larger version
Old 01-11-2008   #38
Are you sure the beam pattern on those is DOT? I think this may be a hazard to the health of my retinas. Brandon please take pictures of the beam pattern before you venture out on the road. thanks.
Old 01-11-2008   #39
OOOOOWWWWWWWww, that shit burned my eye.
Old 01-12-2008   #40
Just did some more work on the baffling I will be putting in to try and keep the air going through the radiator. Also building a small scoop underneath to scoop some air up in from under the car, in to the radiator.
