Old 01-22-2008   #21
Re: Hesitates after 7lbs...
Originally Posted by xveganxcowboyx View Post
To add to this, they are also very picky about plugs in general. Make sure they are the OEM plug and not some fancy platinums or anything stupid like that.
They are the only plugs that I personally would ever run in my car. NGK BPRxES. (he has the 6's i run 7's)
Old 01-22-2008   #22
I completely burned up a set of NGK Platinum plugs in about 4 months of normal daily driving. I've had the set of regular NGK plugs in my car for about 8 months now, and they're still in really good condition.
Old 01-22-2008   #23
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Exactly. I tried Bosch platinums when i first got my Talon. The thing broke up badly in the higher rpms. NGK BPR7's for me now.
Old 01-29-2008   #24
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
any word on what it was??
Old 02-11-2008   #25
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
Did this ever get resolved?
Old 03-11-2008   #26
johnson
johnson's Avatar
Drives: 90mitsu
i think i am having the same problem with my 1g...
ive done a boost leak test, new plugs, and after i replaced a bad injector, it was boosting great.... then i took it out again and was gonna get some gas, then it just stopped boosting after 2500 rpm..... i was wondering if its the turbo???? i checked the wastegate and it still opens but i could not control the amount of psi going in before it opened...
i might pick up some new wires later... thats what im hoping itd be....
Old 03-12-2008   #27
Stopped building boost completly? How does the car run otherwise?
Old 03-12-2008   #28
johnson
johnson's Avatar
Drives: 90mitsu
it runs perfect before boost... but once it starts boosting it just sounds like a lot of backed up exhaust built up... and no boost reading or goin through... but once you get up on rpm.... it starts to read a little boost...
Old 03-12-2008   #29
Pull your intake and check your turbo for shaft play.
Another "test" is you can temporarily unhook your wastegate and CAREFULLY watch your boost. You should build boost and very quickly without boost control.
DO NOT let it swing past 15psi as that is all you need for the test.
Old 03-12-2008   #30
johnson
johnson's Avatar
Drives: 90mitsu
i checked the turbo and ran the wastegate straight through... still same results...
Old 03-13-2008   #31
DSM_421
Coudln't wires have something to do with that as well, not just the plugs... I mean they go bad as well.
Old 03-14-2008   #32
johnson
johnson's Avatar
Drives: 90mitsu
i replaced wires too... not that... im gonna do a more thorough leak test this weekend... im pissed!!!
Old 03-14-2008   #33
So you completely unhooked the WG line, and you are not building boost? Am I understanding this correctly? If that's the case, I'd look at your turbo.
Old 03-14-2008   #34
johnson
johnson's Avatar
Drives: 90mitsu
it still feels like it wants to go but it just cant... you feel power/ no power/ power/ no power... i think the turbo is still boosting, just not through the motor or somethin... beats me... i dont wanna replace turbo in a car i dont plan on keeping!!!
Old 03-14-2008   #35
You think it's boosting? Do you not have a boost gauge? If you don't have a boost gauge, that should be one of the first things you get for that car.
Something else to check is your ignition timing. Check that and tell us what it's at. If you are in fact boosting just fine, but the car is extremely sluggish, your ignition timing may be off, causing a ton of knock, which is what is making your car accelerate so poorly.
Old 03-14-2008   #36
What did your BOOST GAUGE say when you unhooked the wastegate?
Old 03-14-2008   #37
johnson
johnson's Avatar
Drives: 90mitsu
same thing as it had all along...
nothing until maybe 3.5 rpm then about 7lbs...
Old 03-14-2008   #38
There, was that so hard? You need to provide as much info as possible when you're having others trying to diagnose your problem over the internet.
So with your wastegate unhooked, you're seeing a max boost of 7psi by 3.5k rpm's, and it never goes above that? Assuming your gauge is installed correctly and reading correctly, I'd say you either have a MAJOR boost leak, or the problem is pointing to your turbo/wastegate.
Old 03-14-2008   #39
Winner!
Here I will write a proof for you.
If no boost leaks, then dead turbocharger.
If dead turbocharger, then dead exhaust housing or excessive shaft play.
case closed.
Old 03-14-2008   #40
Does it spit and sputter some? When a car is misfiring it can do that type of thing. I would do a boost leak check first, then go from there.
