Old 02-20-2008   #161
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Make slowboy not so slow
the 2g one would be fine for right now... cause i want my garage back dude. :P
Old 02-20-2008   #162
What shape was the turbo in Mark?
Ordering the FP mani with coating soon.
Pete I'll install it with the 1g mani right now, and just change out the FP mani when I get it.
Edit: FP ran out of the coated ones, so I got uncoated for $175, I'll get it coated locally I guess. Maybe I'll talk to FFPerformance, they did Brandon's right?
Old 02-20-2008   #163
the fins are chipped up and it had a cut housing so it took me longer to make a plate and weld it in there
Old 02-20-2008   #164
That sucks, how bad are they? Is it going to hurt performance quite a bit? The center section looked alright though?
Old 02-20-2008   #165
The fins on the turbo are chipped up??
Old 02-20-2008   #166
that they are the guy ran it with out a filter on it has some small chips on the fan. but the center is nice and tight still
Old 02-20-2008   #167
Yea I mentioned to Andrew to check that turbo out, because I knew the guy ran it without a filter... Not good.
Old 03-07-2008   #168
Posting pics for andrew... new setup pics:
Old 03-07-2008   #169
My old turbo! How I missed it. Can't wait to see results from the new setup
Old 03-07-2008   #170
Ok I can post again, was not working temporarily.
Anyway, yea that's your old turbo, but now with 40mm external wastegate thanks to TKR.
The new intercooler looks huge compared to my old one, MAP had to do a lot of bumper cutting to get it to fit, but it looks nice. As a result, I now I have short route piping, the BOV is on the bottom of the piping which is weird, but oh well, I like the way the Type S sounds.
Old 03-07-2008   #171
Yea it all looks good. You need to stop at mitsu and get a new dipstick though. lol
Old 03-07-2008   #172
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
good to see my old tial 40 gate is seeing some use.
Old 03-08-2008   #173
My car idles a lot differently now, it used to be around 20 vacuum on the boost gauge, now it's around 10 vacuum. Also, it used to idle around 40hz, now it's around 70hz for airflow at idle. I guess it makes sense that these two would rise together, but why the change? Just the cams made the difference?
Old 03-08-2008   #174
Aftermarket cams will idle with much less vacuum, 10 in/hg sounds about right.
Old 03-08-2008   #175
craig
wants to kick mark
craig's Avatar
thats where mine idles with bc 280's in it
Old 03-08-2008   #176
I just put HKS 272's in mine, and I'm seeing between 8 and 11 in/hg at idle as well.
Old 03-10-2008   #177
I picked up a Buscher FPR and Walbro 255 hp pump today from Jakey when I was driving through Ames on my way home this evening. However, it's missing the fitting for the fuel return line, hopefully I can get Buscher to sell me just that, or maybe I can rig something up myself.
Also, I had a really great opportunity to learn about ethanol in Iowa. Since Emily's family farms and her brother works for the Iowa Soybean Association, we went to this banquet and there were several speakers, including the Iowa Secretary of Agriculture. He said there are 81 (I think) e85 pumps in Iowa right now, and there are going to be at least 50 more put in this year. I found several along I80 and I35 already, so I could switch and be ok for my trips to Iowa. I also found a couple stations on the way to my hometown, so I'm seriously contemplating switching.
Anyway, the most interesting part was talking with Secretary Northey afterwards. I asked him about the new "blender" pumps they are using in Iowa and southern Minnesota, apparently you can choose the level of ethanol in your gas, and the price goes down for more ethanol. However, he was unsure if you could still get the full e85 blend in the winter. Currently Iowa follows the same dates going to the winter blend as Minnesota, he said the lower ethanol content was for cold starting issues in the winter. Hopefully these new blender pumps allow you to get a full 85% in the winter, since apparently they are mixing the gas at the pump.
He also thought it was interesting that people would convert their non flex-fuel vehicles to use e85, he hadn't heard of it before. I guess he is looking for more ways to push ethanol usage in Iowa, and wanted to use more examples when promoting it.
Old 03-26-2008   #178
Got my gauges installed, they look great. Now I just have to figure out a third gauge for the pod. I took pictures of the gauges off, then with the lights off, then lights on.
I should have everything else installed by the end of this weekend, and I have tuning scheduled with Shane on April 11th. I'll be all set for the cruise.
ID:	7134   Click image for larger version
ID:	7135   Click image for larger version
Old 03-27-2008   #179
craig
wants to kick mark
craig's Avatar
super, looks good.
Old 03-27-2008   #180
Awesome! Seems like more and more people are actually getting their cars tuned, rather than throwing a bunch of parts on them and just tuning them enough so they run.
