Old 05-08-2008   #161
Re: My Winter Upgrades
Well the JMF catch can and SMIM should be on their way shortly.
Also just picked up a Used Laptop for Link. I had been using a real old Sony thing that got the job done, but this one should be a little bit nicer.
Old 05-12-2008   #162
Went to install the fuel feed today, and was taking pictures to make a little write up article for anyone else looking to do this. I quickly found out the adapter fitting that screws into the OEM fuel filter is the wrong thread pitch. I edited my prior post with the part numbers in case anyone else was looking to do this. Originally I thought the banjo bolt thread was 12mm x 1.5, but it is actually 12mm x 1.25mm. Just putting that out there for anyone else.
Old 05-12-2008   #163
very nice. my smim will be here soon also coming from japan
Old 05-13-2008   #164
Yesterday
-Installed the Dual 255 pump setup yesterday. Tested the fuel system for leaks and so far so good.
-Attempted to install new fuel feed line but found I had a wrong fitting so the stock one is back on for the time being.
Today
-Got the oil drain for the turbo fixed up as it was kind of rigged earlier causing a leak.
-Put the EGT probe into the manifold.
-Primed the whole system with oil about 10 times just to be safe. No visual leaks as of yet.
-Put the front bumper and lenses back on.
-Right now Saables Gobbles is charging up the battery a bit before I go and just crank her over and make sure she fires up. There's no exhaust so it'll be loud, and will probably idle like crap considering the O2 sensor is just laying in the engine bay because it has no exhaust to screw into yet. Exhaust should be started sometime this week hopefully.
Old 05-13-2008   #165
DSM_421
Looking good, are those HIDs on the Saab? They look bright as hell!
Old 05-13-2008   #166
http://www.youtube.com/watch?v=AiHGZpxcwoc
Ignore the flames, exhaust should be going on sometime this week hopefully. I'm just glad she started up and actually started to idle semi decently.
And yes, the Saab has HID's. Maybe the Talon will someday too.
Old 05-14-2008   #167
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
yay it runs
Old 05-14-2008   #168
polishmafia
Smells like cat poop
polishmafia's Avatar
woot~! its alive
since i put in my jdm headlights, i cant use my HID kit anymore. i dont remember what harnesses you put in your car (the ones i picked up for you), but its an H4/9003 bulb. you know you want to let the ricer out of you just a little haha
Old 05-14-2008   #169
nice! Glad it runs!
Old 05-14-2008   #170
Pretty sure that is the harness I put in there. It's the same bulbs that the green dragon used.
Old 05-14-2008   #171
Woot! Now get some exhaust on that beast and get it out on the street!
Old 05-14-2008   #172
Towing it up to Momin tonight, and he's going to get at it once he has all the piping!
Old 05-14-2008   #173
Got some other misc stuff done. Had to slot some holes to lower the hood latch a bit to get it to fit better. Also put the hood pins on which helped as well. Hood fitment is much better now then it was originally. Also got the vent attached to the new hood. Put in the new front speakers (thanks mr. hill). Got the interior back together for the most part.
Rinsed off a lot of the dust. It's still dirty but looks a lot better. Cousin should be here shortly to tow her away!
Old 05-26-2008   #174
Couple things that arrived in the mail the other day.
- JMF Race Manifold.
- JMF Dual Chambered Catch Can.
Exhaust is still under construction. Hope to have her back soon!!
ID:	7388   Click image for larger version
ID:	7389   Click image for larger version
Old 05-26-2008   #175
Also got the laptop in the mail! Got Windows loaded on it. I'm real happy with it for paying only $185 shipped. It's extremely light too which will be nice.
Old 05-27-2008   #176
looking good
Old 05-27-2008   #177
Nice. Where did you get the laptop from?
Old 05-27-2008   #178
Ebay. Post 161 actually has the link to the auction I won.
Old 05-28-2008   #179
DSM_421
Catch Can is dope.
Old 05-28-2008   #180
FedEx man left me yet another gift on my doorstep. Who keeps sending me these wonderful things???
17x8 Rota Boost's
35mm offset
Bronze
No tires yet though. If anyone has some decent input or recommendations for a good size to go with, and a good brand that is a good medium between performance and price, I'm all ears. I'm currently researching that right now. I currently have 16's so I need new tires, but I was fairly happy with the Fuzion's I had on there before. Good bang for the buck. But I may need something slightly better now.
