Old 06-15-2008   #101
twack
It was a auto get over it
twack's Avatar
Re: Getting the Laser ready for AutoX
good work son that thing used to be a hack job. now its time to pretty up the hatch and doors
Old 06-16-2008   #102
wants to be sideways...
123abc's Avatar
Drives: Loud cars
If anything I need to gut the hatch and replace the interior door panels.
I can not believe how heavy these fucking hatches are...
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-16-2008   #103
twack
twack's Avatar
the hatch isnt heavy when your struts work
Old 06-16-2008   #104
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
Burn!
Get those bad boys and you'll be happy. www.machv.com is where I bought mine. No more bonking my melon for me!
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 06-28-2008   #105
123abc's Avatar
Drives: Loud cars
Went to work pulling the axles out to replace my axle seals in the tranny yesterday. As luck would have it, I pulled on the wrong part and ripped the boot on the drivers side axle. Ordered a new boot and I just went and got it.
Are the axle seals the only common place for dsm trannies to leak? Mine is completely dirty all over, and I have no idea where else the crap is coming from.
Old 06-28-2008   #106
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Spray wash it off or soak it in brake cleaner to get it semi clean and get rid of all the fluid and dirt around the seals then check for where its leaking.
Axle seals do tend to leak, the more times they are messed with, pulling the tranny in and out, replacing axles and such, the more they tend to leak.
Axle boots are simple to replace also, just rip the old one the rest of the way off, pull the clip holding the CV joint onto the axle and remove it. Clean everything up good, slide the new boot on, crimp the small band first, put the new packet of grease into the CV cup, slide on the axle, put clip back on, and tighten down the large band.
If you dont have the tool to crimp the bands, I do. Just let me know.
Originally Posted by shoutbox
Old 06-28-2008   #107
123abc's Avatar
Drives: Loud cars
Alright, thanks. Go figure, the boot I got was for a 1.8 axle. So now I gotta wait untill Monday for the correct boot.
Old 06-30-2008   #108
123abc's Avatar
Drives: Loud cars
Same problem with the boot. Figured out I have a different driver's side axle. Here's a pic, can anyone help me figure out what it is? Once I figure out what axle it is I can get the correct boot and throw it back together.
I'm FWD too, so no intermediate shaft.
Old 06-30-2008   #109
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Did they give you the inner or outer boot?
Does the boot slide tight over the axle just not the CV cup?
Old 06-30-2008   #110
123abc's Avatar
Drives: Loud cars
Thats the inner. Dsm axle cups are Y shaped, this one is circular.
Old 06-30-2008   #111
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
You are incorrect... Mine is round not Y shaped. The Y is internal for the CV joint.
Old 07-01-2008   #112
123abc's Avatar
Drives: Loud cars
Inside they are round, but on the passenger side axle on my Laser it is Y shaped, but the driver's side is not.
I'll take pics later today, I gotta work in an hour. I had them order the outer boot which is round on the inside and should work.
Old 07-01-2008   #113
123abc's Avatar
Drives: Loud cars
I got the boot today and it fits. Going to slap it all together tomorrow, and enjoy my new Greddy weighted shift knob, and my new leather rear seats to match the fronts.
EDIT: I also am going to try a new replacement for the 5 mph crash beam because I'd rather have one. I got an Aluminum one off a Buick Lesabre from a friend at a body shop. It's pretty close, so we'll see tomorrow. It's about half the weight of the stocker, and the stocker is 32 lbs.
Old 08-11-2008   #114
123abc's Avatar
Drives: Loud cars
Well, after waiting over a month for my foot to heal, I took it out a couple days ago and realised I still got work to do.
I still have some small boost leaks. When I'm at 10-13 psi, I can rev out all the way to 7k. However, when I'm at 15 psi, she cuts out at 5k. I know I have a leak at the tb, and I also got a set of injector o-rings yesterday.
The next autocross is here in Winona, Aug. 16-17th. I plan to be there.
Old 09-07-2008   #115
123abc's Avatar
Drives: Loud cars
I figured out my cutting out issue. Gapping the plugs out helped, but what really helped was re-wiring the fuel pump today. Pulls so much better and smoother all the way to 7k. Tomorrow I'm going to try gapping the plugs out to .28. They are at .25 right now.
Makes me really want a set of cams and a 16g.
Old 09-14-2008   #116
123abc's Avatar
Drives: Loud cars
I use to have this stupid phantom knock issue ever since I got the car. Would only happen at part throttle in vaccum just cruising around. I would get crazy counts of knock that would max out what the ecu can read. Now it's slowly coming back more and more.
Is it my lifters? I can't believe this is happening, the flippin engine is only about 3k miles old.
Old 09-14-2008   #117
twack
twack's Avatar
Calm down dustin you havnt even checked your base timing yet
Old 10-20-2008   #118
123abc's Avatar
Drives: Loud cars
Took some pics tonight. Keeps getting colder, so I don't know how many times I will have it out due to my heater core leaking and unhooked. I also took a video of a 3rd gear pull, but that will take a while to upload.
Here's the pics:
Here's the shaky video:
http://www.youtube.com/watch?v=is6bCV-CKQg
Old 10-20-2008   #119
Would?
How's the weighted knob treating ya?
Would? is offline   Reply With Quote
Old 10-21-2008   #120
123abc's Avatar
Drives: Loud cars
Awesome, although you couldn't tell from the video. I just don't trust my knee without power steering.
