Old 09-12-2008   #661
Re: the evo 3 swap parts are coming
dad and I got the rears all done today. the car is on the ground. just have to blead the brakes some more they are still soft and get the ebrake to work better.
here is the first set of brackets. redid them a 2nd time with a smaller spacers. used just a washer on the 2nd run of them.
also a 18*8 will fit on the rear of a evo I-III arm with 1/8 or so of space
we had to cut the a set of bearing centers for a spacer for the hubs. with out them the hub hit the ebrake.
Old 09-12-2008   #662
the evo I-III arm with the 2nd bracket set up and the evo 9 ebrake set up
put all together with the evo 9 rear disk and brembo
Old 09-12-2008   #663
I those those calipers were from an evo 8?
Old 09-12-2008   #664
they are evo 9 but they are all the same from evo 5-9
Old 09-13-2008   #665
dad,kevin,and I got them all blead out and got the ebrake fixed so it works really well. The evo 9 cables were longer than the evo 3 ones. I still dont like the brake peddle so I am going to pick up a evo 8 master and swap that in. also will pick up a set of rear s.s. lines for it.
Old 09-13-2008   #666
Looks good, love those brembos.
Old 09-13-2008   #667
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Finally! Lookin good, now that paint and that thing will be pure sex!
-1990 Mitsubishi Cyborg 4WD-
Old 09-13-2008   #668
That shit looks good as hell even without a paint job on the car, i think its a good thing, because if that car had a paint job 99% of viewers would instant nut.
Old 09-13-2008   #669
twack
It was a auto get over it
twack's Avatar
to late
Old 09-14-2008   #670
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
That looks awesome mark! Cant wait to see it in person Looks great with black wheels!
Old 09-14-2008   #671
mdost03
Sonic Champion!
Drives: VA STI
Looks great! Size of the wheels on that car doesn't look too bad either.
Old 09-15-2008   #672
Looks good! Its torture waiting for this thing to be one solid color. lol
Old 09-15-2008   #673
Holy shit those 18's look like freakin 20's on that car! Bawlah!!! What tires did you end up going with?
Looks bitchin man. Stop a lil better than the old setup?
Old 09-15-2008   #674
Nice!! Looks good.
Old 09-15-2008   #675
they are the 215/35/18 that I got from a buddy for 125.00 with 200 miles on them.
the car stops like crap right now it is no better than it was before. I have a evo 8 booster and master on the way to fix that problem. The evo III master does not push enuff brake fluid to make the brakes work the way I want them to right now.
Old 09-18-2008   #676
just picked up a evo 8 ecu off evom from a vender for 110.00 shipped
Old 09-19-2008   #677
eclipse_spyder
The most ricest dsm
Looks good but I think the wheels are too big. It makes the calipers and rotors look small. Those tires look thin also. I'd go with 16's if I were you.
Old 09-19-2008   #678
95talonracer
95talonracer's Avatar
I am guessing the wheel size was choosen to be able to fit the new brakes in so he can't go much smaller.
Amsoil Dealer
Old 09-19-2008   #679
eclipse_spyder
The most ricest dsm
I'm pretty sure 16's can fit. My Brembo's, although they are not the Evo's calipers, can fit 16's. 16's makes your brakes(caliper/rotors) huge!
Old 09-19-2008   #680
311evo
311evo's Avatar
16's would not fit over evo brembos, hense them comming stock with 17's with very little clearance.
