Old 12-15-2008   #21
Re: Cold weather issues?
My big problem was that it was cold as hell outside so I decided to stay inside all day!
Old 12-15-2008   #22
311evo
311evo's Avatar
my tranny used to be supper notchy in the winter with amsoil tranny fluid, i now also use the redline cocktail and it acts almost like brand new synchros after a couple days.
Old 12-16-2008   #23
Parking outside for the first time ever during winter. I sure miss heated underground parking. Last year I had underground non heated, and even with my 15w-50 oil, it always fired up. (Bad lifter tick which was solved last spring, now running 10w-30.)
No real problems, just starts a little slower but never more than 2 cranks. Scraping ice and snow sucks too.
I think my car blew a shock out over the weekend, but not due to weather.. UGH
Old 12-16-2008   #24
both rear doors were frozen shut
the washer fluid was 1/2 frozen
shell 10/40 with a bottle of Lucas it a little to thick to a while to run well
the car does not get warm even with the drive to the airport 160 tem t-stat sucks for winter.
the lock was frozen
sliding all over the place with the 18's is not fun
all yesterday
Old 12-16-2008   #25
mdost03
Sonic Champion!
Drives: VA STI
My brake booster was having issues in the -15 weather the other night. When the car was running, the brakes were hard to press like if the car was off. After warming it up, it was good though. Turned over super slowly, but still started up like a champ.
Old 12-16-2008   #26
ylimert01
ylimert01's Avatar
Drives: Nissian
same problem with the brakes I noticed when I started it up to move it, only took one crank but it sounded like crap, but my brakes were frozen so they did not want to move....I actually have places to go today so hopefully she will be good to me.
F Subarus!!!
-Emily
Old 12-16-2008   #27
cmspaz
Walls need hugs too
cmspaz's Avatar
Sounds about right. My belts also scream more than normal when I start it.
It's always been 1-2 seconds of cranking to start, and even in this weather, it's no exception. They're just reeaaaaallllly reeaaaaallllly sloooooooooooooooooooooooow cranks.
Originally Posted by Trogdor
Old 12-16-2008   #28
Well first time my car wouldn't start, battery was toast after 30 seconds of trying to start. I haven't started it in over a week so battery was probably about dead anyway. Getting a jump in 30 minutes.
Old 12-16-2008   #29
The Honda battery has barely started our Talon the last 2 mornings.
Old 12-16-2008   #30
mike55112
mike55112's Avatar
Drives: 04 evo
I have a civic battery in the evo right now and she cranks over like a champ.
Old 12-16-2008   #31
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
I plugged my Grand Am in for the first time ever. I wanted to get heat faster in the morrning and it worked great. Started it, went inside for 2 min, got back in the car and the temp was over 100 already!
Old 12-16-2008   #32
hellomynameis
hellomynameis's Avatar
Chinese Checkers Champion! Elite Mahjong Champion!
Drives: Evo IX
Send a message via AIM to hellomynameis
Yeah, I have a huge cold weather issue! Other drivers!
Seriously, though; my idle sucks but Kracka and I will fix that. Otherwise it's just been fun letting the car get squirley on the roads.
hellomynameis is offline   Reply With Quote
Old 12-16-2008   #33
SnoEclipse
Drives: 07 Eclipse GT
on cable this week 'futureweapons' is running their cold weather episode up at Ft. Wainwright in Alaska.
07 Eclipse GTV6 Deep Red Pearl, cosmetic and weight reduction mods in progress, suspension and brakes come in Spring 2009. I want an LSD for the 5 speed auto!!
SnoEclipse is offline   Reply With Quote
Old 12-16-2008   #34
Other than my low speed spin yesterday infront of my apartment building, I've had no issues at all. My car cranks a little slow when I'm leaving work and idles like shit for a couple mins, but it still fires right up.
Old 12-16-2008   #35
Well I got my car started. Even with it hooked up to another battery, it still took probably 2 full minutes of it cranking/sputtering for a few seconds, then letting it rest for a few seconds. Probably flooded so much it took even longer to start, and when it finally did start, it didn't seem like it was running right.
After consulting with Peter, we determined it had fouled plugs from being excessively flooded, and was probably running on less than 4 cylinders. When I got them out, 3/4 were pitch black, just completely coated. Replaced them with new ones, and it was rough for a few seconds then idled like normal again. I'm not going to let it sit for over a week again unless it's inside the garage.
Old 12-17-2008   #36
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
car's been in the garage to 3 days straight and i just fired it up about 30 minutes ago...started right up. the cars outside (truck) had trouble started a-ok.
ლ(ಠ益ಠლ)
Old 12-17-2008   #37
cmspaz
Walls need hugs too
cmspaz's Avatar
I had no problems this morning. No mushy clutch at cold start anymore, yay!
Did a little drifting, too, in the back lot at Normandale. Took a little bit of work without being able to spool the turbo, but by the end I was able to do a full lap of the lot completely sideways.
Old 12-17-2008   #38
JustROLLIN
SpunBearing
JustROLLIN's Avatar
My TPMS light came on the other night. It was -5 outside and neither my tire gauge or the compressor at the gas station were working correctly. I just drove home on it and luckily it was only about ~10lbs low. But, a good reminder that tires lose air in cold weather.
Old 12-17-2008   #39
1G_DSM
1G_DSM's Avatar
Drives: 1994 Eagle Talon TSI AWD Auto
I couldn't get my car to start for the past 3 days now.
1G_DSM is offline   Reply With Quote
Old 12-17-2008   #40
mdost03
Sonic Champion!
Drives: VA STI
Why can't you spool the turbo? Boost leaks now?
