Old 01-16-2009   #41
Re: My new setup for spring.
Should put up some good numbers, good luck on the dyno and the track!
Old 01-16-2009   #42
mike55112
mike55112's Avatar
Drives: 04 evo
Originally Posted by At-Least-It's-An-Evo View Post
man, i kinda want an evo again...ugh
Just get one, buy another bby one.
Old 01-16-2009   #43
I wouldn't even try to re-use/clean an oil cooler from a motor that put any shavings into the oil. It can be an expensive part of a new motor build to get a new oil cooler from Mitsu or build an aftermarket setup, unless you are lucky to find a used one that you are 100% sure came from a clean running motor.
Old 01-16-2009   #44
mike55112
mike55112's Avatar
Drives: 04 evo
Excactly why I bought a used one from a good motor, I didnt want to spend 600 from the dealership and I needed one asap so I found someone local that is switching to an aftermarket one. This engine was way to expensive to take the chance on an oil cooler that I cleaned out.
Old 01-16-2009   #45
Smart move not re-using it. Re-using a spun bearing victim oil cooler is a great way to burn some money without actually setting it on fire.
Old 01-16-2009   #46
So in that case, if it gets that embeded into the components to the point that you can't clean it out without being able to "scrub" it, do you also replace the oil filter housing, the pick-up screen, the oil-pump, catch-can and all lines, valve cover, the dip stick tube? Where does it end?
Old 01-16-2009   #47
You take all of the plugs out of the oil filter housing and clean it. Sometimes you can clean the pickup screen, sometimes you replace it. You normally change the oil pump with any rebuild. Catch-can shouldn't put oil back into the motor. Hopefully shavings aren't in the valve cover baffles, you atleast clean it. Dipstick tube is easy to clean. So kinda yes. It's just not easy to clean an oil cooler or know if it's clean and it's not worth destroying a motor over it.
Old 01-16-2009   #48
The cost of an aftermarket oil cooler setup is always cheaper then motor damage. What size exhaust housing is that? Nice setup.
Old 01-22-2009   #49
Just got a txt from mike....his ignition is breaking up, but he made ~430whp @ 17psi on RS's mustang dyno. 'full boost' (lol) hits at 4350rpm.
Old 01-22-2009   #50
mike55112
mike55112's Avatar
Drives: 04 evo
Ya I need to invest into spark tech or some type of other ignition setup. We only took her up to 7000 also. Still plenty of power to be made on pump. The just rips now.
Old 01-23-2009   #51
Post up your dyno graph already sucka!
Old 01-23-2009   #52
^Hell yeah.
That shit spools fast. I was getting 22psi by 4200rpm on my 61 on stock 1g bottom end.
Old 01-23-2009   #53
He does have a 2.3l and a GT4088R is inbetween a 61 and 67 in size, so it shouldn't be crazy laggy.
Old 01-23-2009   #54
carlvr4
pretty good numbers on the mustang
91 gvr4 dd, 04 open class sti rally car, 97 k2500 toy hauler
2010 events: sno*drift, 100AW, STPR, OFR, LSPR, NT1-3
carlvr4 is offline   Reply With Quote
Old 01-23-2009   #55
Oh, well thanks for that.
Pirate turbos just blow my mind.
Old 01-23-2009   #56
ARRRRRRRRRR
It's a 63.5mm compressor wheel. There are a couple possible exhaust wheels. We put 2 of the non-R GT4088s on Kenny's TT Mustang. The non-DBB ones used to be dirt cheap.
Old 01-23-2009   #57
mike55112
mike55112's Avatar
Drives: 04 evo
Im actually really not sure when full boost hits, I really diddnt look at the sheet to closley. I will post that up when I get my scanner to work. I need spark tech to turn the boost up so the ignition doesnt break up.
Old 01-23-2009   #58
Sucks about it breaking up but still put down some good power! Was that on e85?
Old 01-23-2009   #59
mike55112
mike55112's Avatar
Drives: 04 evo
No this was at 17 psi on BP92. I was going to turn the boost up to 24 yesterday on pump. I guess I will just have to wait to put down the bigger numbers till I get my tax returns back for a better ignition. I have the dual pumper laying around ready to go in and get tuned on e-85. Heres the graph
Old 01-23-2009   #60
Wow that thing is just dead below 4600! Great top end but the midrange is what kills a setup like that for me. Great power for such low boost though, should be fun to rip around in for a while, but do you think you'll get sick of having an n/a car under 4000rpms?
