Old 01-30-2009   #1
Cammaxon
Brian Spilner called...
Cammaxon's Avatar
Drives: RR EVO Viii 493AWHP Spilner Mobile(sold)
95 TSI project questions
I’m starting to fix up my 1995 TSI AWD that has been sitting for 2 years after the clutch went out and I neglected it because I was focusing on my 04 STi.
The car will need a new front bumper and head lights.
I was considering getting a body kit I know that it’s very unpopular but think about how unattractive the 95 Tsi front facia is compared to the 97+ mitsu. And I would like to get the projector style headlights.
IF I but a body kit for a 97+ eclipse/ talon AND projector style headlights for 97+ will they work with my 95 Talon hood, fenders and how will it bolt on?
Any suggestions?
Cammaxon is offline   Reply With Quote
Old 01-30-2009   #2
Cammaxon
Cammaxon's Avatar
95 TSi Compression
Before I start to put $ into it I know I want to check the compression and timing. I’m currently in Iraq and want to get this all going when I get home. I’m told it’s a 6-bolt, that it has a coolant leak, a boost leak and will need a new turbo. I love DSMs but am I getting in over my head? What else should I have inspected on the car before starting to fix things?
Any suggestions?
Old 01-30-2009   #3
Cammaxon
Cammaxon's Avatar
95 TSI turbo and fmic questions
Before I start to put $ into it I know I want to check the compression and timing. I’m currently in Iraq and want to get this all going when I get home. I’m told it’s a 6-bolt, that it has a coolant leak, a boost leak and will need a new turbo. I love DSMs but am I getting in over my head? I had 315awhp on my sti (tuned at DB) but ended up with a hole in my piston so I want to keep it around stock #’s and boost but I want a fmic. Any ideas on a decent turbo under $600? Used? YES OR NO? and how about a FMIC and piping?
Any suggestions?
Old 01-30-2009   #4
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
Re: 95 TSI body work
I'm not sure but I thought you just needed to switch lights and the bumper to 97+
If you do go with a body kit don't buy cheap, I had fitment issues with mine now I'm back loving the stock look. As long as the body kit is 97+ you shouldn't have any problems. You drill holes into the body kit to match your holes on the car.
Old 01-30-2009   #5
Cammaxon
Cammaxon's Avatar
95 TSi Suspension problems
The last time I drove it, it was very rocky and actually a scary ride past 80mph. I’ve buried the needed in my 04 sti so it wasn’t the speed. I think I’m going to need some suspension work done. What is the cheapest way to fix this problem? How much am I looking on speeding on parts and any one that will help with the work for beer pizza and $50?
Do it for a veteran? Lol jk
Any suggestions?
Old 01-30-2009   #6
Cammaxon
Cammaxon's Avatar
95 TSI brake questions?
I KNOWWW the car will need new rotors and pads, idk about lines. What is the cheapest way to upgrade my brakes? I’m not looking for (B)rembos although I loved them on the STi but I don’t want crap parts.
Any suggestions?
Old 01-30-2009   #7
Cammaxon
Cammaxon's Avatar
Where is a good place to get a kit? any links?
Old 01-30-2009   #8
Re: 95 TSI project questions
I merged your 5 threads into this one big project thread for you.
Old 01-30-2009   #9
Yea if you get a 97+ bumper just get the lights to match, they'll both bolt right up, don't worry about the hood or fenders.
MAP is trying to clear out some of their DSM powerslot rotors I think, I'd go with those.
As for a suspension setup, I may have my Tokico HP setup for sale soon, probably looking at a $200 range.
Old 01-30-2009   #10
Cammaxon
Cammaxon's Avatar
Thaks for the merge!!
$200 would be great for the suspension! what condition is it in? how much use could i expect from it?
Ive spent a lot of $ at Map so ill have to look into the ps rotors how about pads?
any one that could do a compression check and timing check for me for a decient price?
Old 01-30-2009   #11
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
I'm not sure how good this site is www.bodykits.com if you decide to buy from them email with questions about fitment, durability, quality of a specific product.
Also you can find some good projector headlights on ebay for around 150 shipped.
here's a picture of mine
ID:	8184   Click image for larger version
Old 01-30-2009   #12
MAP or DB should be able to take care of that fairly quickly/cheaply for you. Since you live in Big Lake, DB would be closer since they're in Rogers.
Old 01-30-2009   #13
You should be able to check compression and base timing yourself. Vfaq.com or www.plymouthlaser.com are good references to show you how to do it yourself
Old 01-30-2009   #14
You could buy a timing light and compression tester for under $50 probably.
As for my suspension, it's in great condition but I'm switching to coilovers. If I don't like the ride I'm switching back, but we'll see after I get it installed. It lowers about 1.7", you can see a bigger picture in my profile. They have about 10k miles on them over the past 18 months.
Old 01-30-2009   #15
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
I have a set of 97+ projector headlights that I used on my car for like 2 months and are practically brand new! Ill let them go for 100 dollars... You can pm me or text me at 651-442-2489 I also have pics upon request
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 01-30-2009   #16
Cammaxon
Cammaxon's Avatar
The 1st thing i have to do is get it running. Then ill do all the other stuff. where should i have the clutch put on? or is there any one on here that could do it for a good price?
Old 01-30-2009   #17
There are some people on the board that do side work, yea. When you're changing the clutch be sure to verify that you have a 6 bolt motor. I guess there are other ways but it's easy when you're staring at the flywheel.
Old 01-30-2009   #18
Constant_Project21
Constant_Project21's Avatar
Drives: E36
If you're good at being creative, ebay fmic kits are very inexpensive, but they take a little work to make them fit. Ebay fmic's are not terrible either, they be more than enough if you're not planning on putting up huge HP.
Old 01-30-2009   #19
Cammaxon
Cammaxon's Avatar
stupid ?. besides a bolt. lol jk whats the differance between a 6 and 7 bolt?
Old 01-30-2009   #20
6 bolt motors came on 92 and earlier dsms, the early 2g 7 bolt blocks sometimes have crankwalk issues. But there really aren't many differences.
BTW, it's the number of bolts holding the flywheel on.
