Old 02-04-2009   #201
Re: 4b11t going into new RWD Hyundai coupe
Or, keep the F20C in the S2000!
Old 02-04-2009   #202
wow lets hope for sub 20k! I'll take a an r spec still
Old 02-05-2009   #203
So I found an online service manual for this, and things don't look good for the block design. It will use 2 bolt mains, and I'm not totally sure yet, but it's possible it's an open deck design. So that means they probably just threw some different rods and pistons, and oil squirters in a non turbo block and called it good enough.
Old 02-05-2009   #204
Thats not good
Old 02-05-2009   #205
eh, it'll still be awesome. The thing is, the bolt patterns will probably be the same for the bellhousing. The motor mounts will most likely work from engine to engine, so a 4b11t swap (I bet) will be a pretty straight forward operation. Plus, it'll be an adventure to find the limits of the stock block!
Old 02-05-2009   #206
Ghey.
Old 02-05-2009   #207
aww, such pessimism. Be happy! a turbo 4 banger rwd coupe. When was the last time we had such a sweet car? (my guess is about 1982-1989, booyah!)
Old 02-05-2009   #208
The Evo X motor is open deck and the 4G63s are 2 bolt mains.
Old 02-05-2009   #209
Isn't the Evo X 4B11T a semi-closed designed basically meaning a reinforced open deck?
Old 02-05-2009   #210
I know the 4g63s are 2 bolt mains, but I thought the EvoX motor was semi-closed deck? I still plan on getting one if I like the way it drives, and I'm not too worried about the block cuz I don't plan on making a ton of power anyways.
Old 02-05-2009   #211
I think the point was simply that it's not looking like it's the EVO 4b11t.
Old 02-05-2009   #212
Yeah, that was my main point. I think this motor should still support 400whp easily. Appearantly these blocks are similar to the ones in the new Caliber SRT4, and there's people making 500whp on the stock internals.
If anyone else is interested in the service manual website, it's: http://www.hmaservice.com/ You have to create an account, but it's free to use.
Old 02-05-2009   #213
Looks like 2.5 bar MAP sensors from the manuals, which are good for 20-22psi. And high impendance injectors.
Old 02-05-2009   #214
Returnless fuel system.
Old 02-05-2009   #215
I think I'll keep my Talon.
Old 02-05-2009   #216
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Gay...
Gayer...
This car is heading in the same direction as Spaz and the Rubber Fist!
Originally Posted by shoutbox
Old 02-06-2009   #217
Ouch, that one sucks. I didn't think the rest was too bad. I thought they were making this mod friendly?
Old 02-06-2009   #218
Why is a returnless fuel system so bad? Does that mean trying to run larger injectors is much more difficult?
Old 02-06-2009   #219
^^ I was wondering that too. I would think that as long as the fuel rail sees the same pressure, it wouldn't really matter if the fuel is constantly flowing through. I could see it being difficult to run a larger fuel pump though. But at the same time, I wonder if it would really need a large pump since it wouldn't have to work as hard to maintain pressure.
Old 02-06-2009   #220
This car fail.t
Not really just making good excuses to not want one. lol
